Results 1 to 12 of 12
Thread: vn still stalling after complete fuel system change
    vn berlina wagon
    Jun 2010
    Unhappy vn still stalling after complete fuel system change
    ok so i have a vn 5 spd manual wagon and its been playing up for weeks also bear with me i am female and dont know correct terms .. what its doing is stalling like its out of fuel (when its low under a quarter) so far ive replaced a pump a filter a sending unit and all main fuel lines and a pressure regulator and still have the same issue .. to me it feels like a blockage because sometimes its like it sucks the shit thru (while its playing up ) and away she goes again other times it just completely stalls n and has no accelerater most times i can start the car straight away n it goes no problems other times i have to pump the accelerator .. argh its sending me loopy im at wits end trying to work out the issue anyone whos experienced the same issue and resolved it PLEASE HELP ME the next option is to have a bbq off the mongral lol
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    It might be the pickup oin the tank is not moving up n down with fuel level.
    Mine does this when it gets to about 1/4 it gets stuck and wont go down with fuel level to pick up the fuel. when you go arpound left hand conrers the fuel runs to the other side of tank and then it feels like there no power till the petrol comes back over and it picks up power again.
    I CBF fixing it atm so my solution is not to let it run low on petrol (cant be helped all the time though)
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    Coast_Calais is offline sick of the idiots here
    varies
    Jul 2008
    gone
    i was thinking crank angle sensor next, but you say it ONLY happens under a quarter tank?
    assuming the fuel has been dumped when replacing pump, filter and sender, only guess would be it's incorrectly reading (float not accurate) or the pickup is not located properly...
    one method to try is when your car reports a 1/4 tank, drop the fuel and measure the qty... ?
    Commydoor's Avatar
    Commydoor is offline born in the FB era
    Vr Ss Blown
    Sep 2007
    Beresfield, NSW.
    do you fill the tank every top up? does it only happen at 1/4 tank? has the tank ever been out?...something to check is the breather for the tank...if theres a blockage or has been re-hooked up incorrectly then you may be suffering from a vacuum in the tank fault...as the fuel is used no air replaces the used fuel volume and a vacuum is created...the more fuel used the greater the vacuum created and by 1/4 tank the pump cant draw fuel against the amount of vacuum...this is one of many possibilities and is most likely not the cause but its worth eliminating...
    vn berlina wagon
    Jun 2010
    thanks guys for the replys .. all hoses have been changed and pumps been in and out about 7-8 times in the last 4 days so i dont think he could put it in wrong everytime .. always makes sure sender unit is facing right way with float right way , but we have a theory ...map sensor?? crank angles fine no dramas there the fuels smelling eally rich too unsure if this is due to mixture next options is changing sensors im guessing if not computer reset ? what do u guys think .. and pub it seems that way but im noticing it on corners and hills heading up ....
    vn berlina wagon
    Jun 2010
    Quote Originally Posted by Coast_Calais View Post
    in saying that coast i would completely run out of fuel wouldnt i ? the car starts right away ...and broom broom off i go lol bear with me as i said female with a blonde brain ... weve dropped the fuel at the line above empty n got out about 10-15 ltrs out n its black shitty fuel not sure maybe the tank needs a flsuh ?
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Have you checked for fault codes?
    MAP sensor should show up if faulty
    VN Commodore Series 1
    Sep 2005
    Sounds to me like you have water in the tank. Sometimes can happen over time from condensation, sometimes all in one go from crook fuel from an independent.
    Only solution - drain the tank completely and fill with 20l of fresh fuel from BP or Mobil.
    ".....any longer on that road and I'm one of them.......a terminal crazy....."
    FXST01's Avatar
    FXST01 is offline The Grey Man
    VP V6 Auto Sedan
    Jun 2005
    El-Arish-Shamal-Sina-Egypt
    Is there a return line inside the tank? And if so does it flow back to the pump/swirl pot or does it just flop down inside the tank?
    Also the pick up point doesn't move with the fuel level, only the float for the guage does.
    Illegitimi Non Carborundum
    vn berlina wagon
    Jun 2010
    Wink
    Quote Originally Posted by Gosling1 View Post
    quite possible .. will check for faults in the morning pub ;-) and ive also been told the united service station i get my fuel from has blown heaps of peoples pumps in there cars .. time for a change today i put in 15 lts of bp fuel see if this flushes it if not time to drain n re fill thank all
    Sep 2005
    water sits at the very base of the tank / swirl pot, because its heavier than petrol - and you only need a bit in there to cause problems (even 1/2 litre is a lot of water in a tank)..........I filled up at an independent in Sydney a couple of years ago.......what a mistake ! Car ran like a dog for days afterwards, i ended up dropping the tank and emptying it completely. It had over 1 litre of water in there !!!
    For a quick & easy fix - throw in 1 litre of methylated spirits into your tank, and drive it to empty. Metho absorbs any water that might be in your tank, and may help with your problem. Just keep a 5 litre fuel container in the boot so when you *empty* the tank while driving, you have enough to get to the closest servo. You have to empty the tank though for this method to be 100% effective.
    vn berlina wagon
    Jun 2010
    thanks gosling i will try this, this afternoon ... hope its cures the problem .. theres alot of black shity stuff liek charcoal in the bottom of the tank and it came out of the filter aswell a few weeks back ... so metho first if no improvement ... drain the tank n have a flush .... ive also read that water in the tank can come from sources such as contaminated fuel or just driving in the rain to the lines at the servo not being closed properly during a hard down pour.. also ive been told that a sweet smelling fume coming through the car can be a contamination to ...which is what im noticing .. its almost on the money that everytime it gets just under a quarter in a 80 km or under zone shes garenteed to #### up !!
  1. [SA] Complete LPG System For A 253 308
    By ENV5 in forum Parts And Other Items For Sale
    Last Post: 12-07-2009, 12:55 AM
  2. [SA] Vt complete gas system
    By 86VL5spd in forum Parts And Other Items For Sale
    Last Post: 30-06-2009, 10:04 PM
  3. [WA] F.S NOS wet system suit efi complete
    By clubsport_replica in forum Parts And Other Items For Sale
    Last Post: 29-06-2009, 08:51 PM
  4. [NSW] F.S: Complete exhaust system
    By RebelSS in forum Parts And Other Items For Sale
    Last Post: 30-12-2008, 03:24 PM
  5. to complete my system....
    By lasco in forum Car Audio
    Last Post: 18-11-2007, 09:08 AM
