Results 1 to 6 of 6
Thread: VG Ute running rough
    VY2 S, VS exec and VG ute
    Mar 2011
    east gippsland
    Default VG Ute running rough
    I have a 90 VG V6 ute S1, its got a few issues with it. I have really tried nothing to correct it but am gonna look more into it when I start driving it.
    It smells like it over fuels abit, if you give it a boot it takes abit to settle back to a nice idle. Either wants to rev hight for abit or nearly stalls. Smells fuely often.
    It dose use abit of fuel..about 350kms highway. You can not coast at low speeds and it gets all jerky (manual).
    A few odd things I have noticed is - it has a tacho dash but seems to not work as it should, dosent seem to rev in time like it should and seems slow. I notice rev increases maybe 50-100rpm but tacho seems not to register minor rev changes and the temp always seem to not move.
    I`m going to try-
    clean/replace O2 sensor
    clean TB and IAC sensor
    replace coil pack/DFI with later model units
    Anyone able to suggest anything or tell me am I on the right track and maybe missing seeing a issue
    1990 VG Commodore Ute
    Mar 2011
    Cairns
    dude i have exactly the same car and i have the fuel problem aswell its really weird...
    Why did the plane crash?
    Because the pilot was a loaf of bread
    Mar 2011
    east gippsland
    the reason I mentioned the dash issue was I was reading another post and they were saying that sensor data goes to the dash first and then to the ecu. If this is the case maybe the car always things its cold hense running rich all the time. Main issues that concern me is the fuel smell and the jerking when coasting.
    Will take a crack at a few things this weekend and see how I go.
    Any suggesting would help me and now ben
    1990 VG Commodre ute
    Mar 2010
    I also have a VG ute....the rough idle sounds like your fuel regulator....I had the same problem...replaced it and all it good. I get about 9.5-10km per litre on the highway doing about 110kmph
    Bazza
    car
    Jun 2010
    have you ran a diagnostic scan? mine was doing a similar thing, turns out it was a TPS.
    Mar 2011
    east gippsland
    I personally havent, will do this weekend. Only got it back on the road today. Bit of a up and down idle and still got the jerks
  1. Running rough as, running hot..Ideas?
    By Maxxiz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-10-2010, 11:29 PM
  2. VN V6 running rough
    By bluvn in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-04-2010, 07:13 PM
  3. Vn - Rough start & Rough Running Below 2k
    By ghog1726 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-03-2009, 10:02 PM
  4. VR Engine light stays on running running alittle rough
    By AJKoo1 in forum General Discussion
    Last Post: 07-09-2006, 01:08 AM
  5. running rough
    By Rumbl in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-01-2005, 05:24 PM
