Results 1 to 2 of 2
Thread: VG ute starting problems
    Looking for that one :P
    Feb 2009
    Brahma Lodge, SA
    Default VG ute starting problems
    when i start the car it will turn over but not fire untill the oil light turns off, thinking oil pressure problems need help though cheers Brad
    FXST01's Avatar
    FXST01 is offline The Grey Man
    VP V6 Auto Sedan
    Jun 2005
    El-Arish-Shamal-Sina-Egypt
    Well your description tells me its a V6? If the fuel pump relay fails, power will be supplied to the fuel pump via the oil pressure switch. When starting the engine, the fuel pump will not operate until the oil pressure is sufficient to extinguish the oil pressure warning light.
    Illegitimi Non Carborundum
  1. VZ SS random problems starting and also lock problems.
    By alista in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 14-12-2010, 11:23 PM
  2. Starting problems when hot VT
    By roxy84 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-09-2010, 01:03 AM
  3. VQ 5L starting problems when hot.
    By Scido in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-05-2010, 11:28 PM
  4. ignition problems or starting problems
    By Vs-AclaimII in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-10-2006, 04:55 PM
  5. vp starting problems
    By driver in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-04-2005, 12:11 PM
