Results 1 to 6 of 6
Thread: vn vp project
    S/C VX Calais
    Apr 2010
    canberra
    Default vn vp project
    first of sorry to all those vn vp lovers..
    just wondering if anyone had done a vr vs dash and/or front end conversion on a vn vp?
    because i was thinking about doing it for fun..
    does anyone have pics so i can see how it looks?
    Vn
    Nov 2006
    Glen Iris, Vic
    yeah mate check ive done a vs dash conversion then upgraded that to a vr statesman dash, and also have put a vs ss front on.
    my suggestion is if ur considering putting power windows and/or climate control then do a loom upgrade as well so u get all the functions, its possible to keep ur existing ecu and engine loom and you will still have the security functions of that from a hi/lux bcm.
    started out but with vn lvl 3 cluster
    then vs dash and climate control
    at night
    now stato dash
    outside
    this
    to this
    S/C VX Calais
    Apr 2010
    canberra
    wow that looks pretty good. how'd you go about putting the climate control in? was it simply swapping the looms or is there more to it?
    and with the front end did everything bolt up or did you have to modify anything or make your own holes?
    S/C VX Calais
    Apr 2010
    canberra
    oh and with the light, hazard buttons ect ect.. was that just switching a loom?
    Vn
    Nov 2006
    Glen Iris, Vic
    i have a vs berlina s2 wiring loom in it with my origonal vn manual motor and ecu.. so i had to do a little bit of patch wiring between teh loom and ecu.. then everything from climate to power windows was plug and play.
    yeah everything pretty much bolted up ull have to make like 2 holes for the bracket that holds the front of the guards/bumper section. then the headlights were a pretty much fit aside from u couldn't bolt up a few bolts..
    yeah if u decide to patch it. keeping ur vn body loom.. the ull have plenty of wires u need to modify for all of the dash.
    climate control you have to remove the whole hvac box. which is the big black box behind the dash. like 8 bolts and plug it into ur new loom or patch in 11 wires from ur old loom.
    S/C VX Calais
    Apr 2010
    canberra
    wow it sounds a bit complicated but im sure if i knew what i was doing it wopuld be easy, i might give it a go one day and see how i go thanks for the help
  1. Replies: 27
    Last Post: 21-06-2011, 08:31 PM
  2. My Project Vk
    By Dirbatua in forum VB - VC - VH - VK
    Last Post: 27-04-2010, 09:24 PM
  3. VR Project
    By impulsive in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-03-2010, 08:48 PM
  4. Project: WMC
    By Niggadore in forum Car Audio
    Last Post: 18-07-2008, 01:26 AM
  5. v8 vh project
    By grassy in forum Projects
    Last Post: 19-08-2006, 02:31 PM
