is it a difficult job to change the steering wheel in a vg ute to a modern wheel...its column shift
Why did the plane crash?
Because the pilot was a loaf of bread
when you say monern, do you mean just a aftermarket wheel or a factory wheel. You will require a wheel puller tool (super cheap have them). Pretty easy job. Unsure is the spline/size are the same on later models.
If your refering to a aftermarket wheel you can get a a boss kit to suit the ute/ wheel you desire...
cheers dude ill probably go boss kit i reckon probably the easiest way
