Results 1 to 12 of 12
Thread: ecotec in 1991 vg ute
    1991 vg ute
    Apr 2011
    macarthur vic
    Default ecotec in 1991 vg ute
    hi all,i am atm doin up a vg ute as a p plater car, its original a buick with a 8 bolt flywheel and a t5. I have cut out the firewall and am puttin in a vs firewall with the dash, I am wondering if i put the vs ecotec motor with the wiring off the motor and the ecu will this work as the rest of my wirng for my dash is gonna be a vr loom. Any help will be much thanks
    vp calais, vn calais, vp berlina all 3.8 litre
    Aug 2008
    Pascoe Vale South, MEL
    im kinda confused... not sure you had to cut out the fire wall. if your putting in a vs engine loom and computer with a vs dash, wouldnt it be easier to just put the vs dash loom in too? i did a series 1 vn calais swap to a vn lexcen (series 2 vp engine) i just swapped everything over including the body loom so theres no conflicts anywhere... the only thing i dont know about is if your body loom will plug in 100% or not... if you got a vg 91 ute where does the vr loom come in?....
    dont sweat the petty... pet the sweaty...
    1991 vg ute
    Apr 2011
    macarthur vic
    i met that i have cut my firewall out due to the vs dash having different mounting points to say the vn dash and the de-frosters are a different setup. The vr dash loom came into cause i was original gonna put the buick back in the car and i found a vr with a buick in at the wreckers, and the vs-vr dash are the same, so i grabbed the loom outta of it. But now i am interested in a ecotec, just curious if i can put a vs engine harness and computer in, and i will change the dash loom to vs one if its easy done.
    Aug 2008
    1991 vg ute
    Apr 2011
    macarthur vic
    Quote Originally Posted by hi_ryder View Post
    check this one out...
    Ecotec to VN/VP
    yea i had a look at the other day, just i dont wanna do it that way, i would rather just convert the whole thing over to the vs if its possible
    HoZy's Avatar
    HoZy is offline //There Ain't No Rest For The Wicked...
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    Then buy a VS
    My VN had a VY Ecotec motor + VS Caprice Dash...
    The dash bolts in, Fibreglass your own underdash vents. All mounting holes are the same.
    Soo..
    Why do you think nothing bolts up and/or works...
    Quote Originally Posted by garth
    well if it isnt mr i only have temp bans. how long you intending on staying this time hozy.
    1991 vg ute
    Apr 2011
    macarthur vic
    i dont wanna buy a vs, as i got this cheap and the body is straight as, and i have spent hours on doin a respray and smoothin the engine bay. I thought it was different cause the vs dash has got 5 bolts to hold the dash the vn one has 3? correct me of i am wrong.
    VS Senator
    Oct 2009
    Quote Originally Posted by pollock12 View Post
    that sounds about right but it will still hold up with the 3. i had a vs dash in my vn and with the 3 bolts it sat in there fine
    1991 vg ute
    Apr 2011
    macarthur vic
    doesnt really mattter now already cut it out. And got a firewall out of a vs from comcar.
    1991 vg ute
    Apr 2011
    macarthur vic
    Quote Originally Posted by HoZy View Post
    Then buy a VS
    Soo..
    i like the way u have done the engine with all the buick pieces extra well done. but i would rather just put the whole lot over motor harness and computer.
    VS Stato l67
    Mar 2009
    Melb
    www.l67torque.com • Login
    Have a look at the link I posted above. There is a lot of information there on putting supercharged ecotec's in VN-VR's so you might be able to apply some of that knowledge to your project. Ive seen your car on SC it looks like a wicked project. I was looking at VG utes a while back but they were mostly overpriced and trashed unfortunately
    1991 vg ute
    Apr 2011
    macarthur vic
    thanks mate, i was lucky with this one, where i use to live it was just 5 houses down and was out the front of his house for months and asked him bout it and yea $1250 later had it. was a fair bargain with a manual and one little tiny dint in the tub, which popped out
  1. 1991 VN, my first V8 :D
    By Sharoo in forum VN - VP - VG - VQ
    Last Post: 17-04-2010, 12:19 AM
  2. [QLD] 1991 vp v8 BT1
    By v8_bomberdore in forum Vehicles For Sale
    Last Post: 29-06-2009, 05:50 PM
  3. my first car 1991 VN LE
    By BUSTA in forum VN - VP - VG - VQ
    Last Post: 15-01-2009, 04:09 PM
  4. 1991 Hsv Vn T30
    By bdiddy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-08-2008, 08:11 PM
  5. 1991 Hsv Vn Ls ?
    By DF_Media in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-03-2005, 12:19 AM
