So winters on the roll and i have no heaters!
I dunno how it broke, 1 day they worked the next they didnt. heres my situation, only the foot wells seem to work, when ever i turn the dial on the climate control nothing happens? it still just blows out the foot wells. when it was all functioning properly id switch the climate control and it would make a wee gas releasing sound,... now nothing?
Anyone had this problem before?
Also the window defogger doesn't seem to blow out the top of the dash anymore which is crap, because the window fogs up something crazy.
Please help!
Sound slike the vacuum lines arent connected if it doesnt hiss when changing. Vacuum runs from the motor to the vacuum ball/resivious mounted behind gaurd? or under front bar cant remember where it is it then goes from this to your hivac unit(heater box) follow the lines see what unplugged or broken. Also if your have youe heater controls out check to make sure itsplugged into the back of it.
Also though not related to your problem by the sounds of it your heater should be replaced if it hasnt in a long time its amazing how much better your heater works with a new tap
Originally Posted by Smidy
