Results 1 to 2 of 2
Thread: VP V6 Ute, Fuel Pump???
    VP ute
    Feb 2011
    Geraldton
    Question VP V6 Ute, Fuel Pump???
    I have a 93 vp v6 ute, and it has a problem in that i have to crank it for 20-30 seconds to get it to start if it hasn't been run for a few hours, switch it off and come back half hour later and it'll start no worries.
    When i turn the key on i can't hear the fuel pump until i get the ute started.
    I read somewhere that if the fuel pump relay dies it uses oil pressure sensor or something to power the pump.
    I have replaced the relay, fuse and upgraded the the pump to a bosch 023.
    All the wiring seems to be ok.
    Can anyone help me?
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    It should prime when you hit the ignition the switch on and then switch off after a couple of seconds, the once started the fuel pump is activated by the oil pressure switch which obviously gets oil pressure while engine is running, then the oil pressure switch completes the circuit and activates the pump, idea being if your in a crash the pump turns off and doesnt keep feeding fuel into the engine bay and adding fuel to the fire (if there is one of course). You can short out a connector down near the kick panel is a little hard to find but its there, its a 6 pin plug from memory, you short out the top and bottom pins on one side to activate the diagnostic mode, and the opposite end to activate the fuel pump.
    Its seems as if the computer isnt activating the pump, check over the plugs near the battery and around the car, could also be a broken wire somewhere.
  1. VS commodore CAS or Fuel Pump? Fuel pump new BUT not priming on accessories
    By robert422 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-04-2012, 08:14 AM
  2. [NSW] Twin billet fuel pump holder for all BOSCH 040 044 pump
    By HIROLLA in forum Parts And Other Items For Sale
    Last Post: 20-01-2011, 08:42 PM
  3. have had to wack the fuel tank to start my car!! is my fuel pump stuffed?
    By CV6Z in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-08-2010, 04:13 PM
  4. cracking open fuel tank to change fuel pump?!
    By VS5spdV6uteowner in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-01-2009, 08:00 AM
  5. leaking fuel damper and fuel pump adventures
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 18-08-2006, 04:00 PM
