Results 1 to 7 of 7
Thread: vp doesnt handle so well.
    vt s pack manual
    May 2009
    gawler, adelaide
    Default vp doesnt handle so well.
    okay so i have a vp calais, its on super lows and 17s with federal EVO tyres ( epic grippy) and since i bougt the tyres i have noticed a change but not enough, the car seems to be far to light on the steering, and it wonders all over the road at high speeds wich is pretty dangerous, i do know that the calais has load sensative steering so the faster i go the damper the steering gets but it doesnt make enough diffrence, does anyone have any ideas ? i was thinking a heavyer sway bar by whiteline or something like that but i really have no idea with this sort of stuff. any help would be apreciated!!
    cheers, Ethan.
    vp calais, vn calais, vp berlina all 3.8 litre
    Aug 2008
    Pascoe Vale South, MEL
    do have adjustable strut tops? lowering would have changed your camber. original sway bar rods? i changed to the aftermarket bent ones with nolathane bushes helped a bunch... just an idea...
    dont sweat the petty... pet the sweaty...
    vt s pack manual
    May 2009
    gawler, adelaide
    i do have adjustable strut tops, but i havent had a play around with them and all the bushes have been replaced and so have the sway bar rods.
    1992 VQII Statesman
    Sep 2008
    Check wheel balancing, condition of shocks, condition of front radius rod, sway bar and control arm bushes. A problem rack and pump only come into play with parking, full lock, with overall road holding not so much. Strut tops wouldn't be so much of a problem either only if the camber is out. Get a proper wheel alignment and make sure all front bushes are good
    1992 VQII Statesman
    1991 VP Calais/ 1992 VP Calais
    1992 VPII Vacationer Wagon
    vt s pack manual
    May 2009
    gawler, adelaide
    i know all the bushes are good, and none of my rods are bent. the shocks are pretty piss pour, do you think that could be the problem ?? ive been told using v8 spec springs and shocks it would firm it up a fair bit, ??
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    get a wheel alignment 1st up and see what it does. Good quality shocks will help. As for springs - really depends on the balance of the car. V8 might fronts will stiffen it up no question but you might find it gives the car too much over steer. I'd look at putting in some quality shocks - kyb are a good budget option or you can spend as much as you like up the scale from there. I doubt springs are your problem - maybe shocks if they are totally rooted. Not enough castor or camber will make the car feel very nervous at speed. Setting the angles correctly will make a world of difference.
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
    vt s pack manual
    May 2009
    gawler, adelaide
    yeah i might look into that option, cheers reaper.
  1. VH Headlights, something doesnt look right !!
    By SLE Lover in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 23-06-2009, 06:51 PM
  2. Help! Vt doesnt do burnouts
    By fatboy15 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-10-2008, 10:41 PM
  3. Man, something just doesnt add up
    By Paiste402 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 01-04-2008, 11:50 AM
  4. It doesnt come off?????
    By Danzilla in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-11-2005, 01:53 PM
  5. Why doesnt it sound right....
    By Nikkojoe in forum Car Audio
    Last Post: 28-09-2005, 01:50 AM
