Results 1 to 14 of 14
Thread: Duragear 75W90 oil okay for VN V6 box?
    VR Commodore V6
    Sep 2008
    Sydney NSW
    Default Duragear 75W90 oil okay for VN V6 box?
    Hey guys. I've recently had to replace my pressure plate, so I've obviously had to take the gearbox out, which meant draining it.
    But I haven't got any gear oil that I used last time, so I was wondering if the Duragear 75W90 gear oil we use for our landcruiser gearbox is fine?
    Cheers.
    Quote Originally Posted by PaRaDoX View Post
    btw do you plan to fly? looks like you have a gauge for everything, refreshment levels gauge, washer fluid temp? penis pump vacuum? *runs and hides*
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Why is "power" so important? Do you have a little dick?
    People are too obsessed with how much "power" their car makes....it doesn't make power, it produces torque, from which this mythical "power" figure is calculated.
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    should have dx3 trans fluid in it not gear oil
    VR Commodore V6
    Sep 2008
    Sydney NSW
    Shit, manual, I forgot to say...
    в∞ѕтεכ √&
    Jul 2008
    NZ
    yes manual the T5 is a worldclass model and requires the use of DX3 trans fluid for it to shift properly use DX3 and a tube of nulon gearbox additive.or fill with redline shockproof oil if you want to spend $$$
    VR Commodore V6
    Sep 2008
    Sydney NSW
    Shit. I think I put in 75/90 gear oil last time, and it fixed the problems I was having with 2nd gear being difficult to engage, and I'm pretty sure ATF came out of it.
    Why does my service manual suggest 75/90 gear oil then? But many others suggest ATF?
    в∞ѕтεכ √&
    Jul 2008
    NZ
    i think the vn book was a missprint LOL gear oil just kills the synchros fast
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    VP book says the same, 75w 90. The genuine book would not have a mistake like that, escpecially over two models. Vr are the first to be world class according to the genuine Holden manuals. I run 75w90 in my VP T5 and ive found it to be fine. There are countless threads on this subject, most end up in a JC b***h fight lol.
    Also the Penrite lubrizol bottle specifies its for World class transmissions and in brackets VR commodore forwards.
    VR Commodore V6
    Sep 2008
    Sydney NSW
    Yeah, see a year ago I was having problems with the 2nd gear synchro, which meant it was grinding sometimes when I'd try to engage. But only when warm. So I changed the oil with 75/90 gear oil I had here, and it was fine. Stick was only fractionally more difficult to move on COLD winter mornings, but after five minutes, everything was fine, and I never had another shift problem again.
    в∞ѕтεכ √&
    Jul 2008
    NZ
    the synchros in a world class box have a lining on them made from the same stuff automatic clutches are made of thats why they say use dx3.we now run a 70% dx3 30% gear oil mix (pretty much redline shockproof) with a tube of nulon just so we get some impact resistance in the manual turbo at 450+hp havnt killed a box since .weve killed them with gear oil and trans fluid sperately.but they do shift the nicest with the reccomended dx3 or the thin shockproof stuff.vn boxes to vr boxes are all borg warner world class T5's and the synchros dont last long with gear oil as we have found out a few times :P
    Blown V6 Hatch's Avatar
    Blown V6 Hatch is offline Too many projects.....
    VN Calais 5.0, UC Torana hatch 383, WB Ute 5.0
    Jun 2005
    Cowes, Phillip Island
    I always used Castrol VMX 80 in my T5. Behind a 200rwkw L67 for about 6-7 years, never had a single problem with it. Treating a T5 with a bit of respect is the key to a long and happy life IMO.
    VR Commodore V6
    Sep 2008
    Sydney NSW
    Well, mechanical sympathy is the key to keeping anything going for a long time.
    VN wagon
    Mar 2011
    I would agree, but then there's the old bombs that no matter how much you fang the daylights out of them, they just keep on keeping on.
    vs commodore
    Oct 2009
    Tamworth NSW
    Ive got the VP,VR and VS gregorys workshop manuals,and Ive got a haynes VN to VS V6/V8 workshop manual and they all say that the early T5's (VN-VP) use 75w-80 gear oil and the VR and series 1 VS T5 manual boxes use dexron 111(3) auto trans fluid and 150 ml's of lubrizol.The later series 2 getrag manual box in the VS uses 75w-85 gear oil.
    VR Commodore V6
    Sep 2008
    Sydney NSW
    Quote Originally Posted by kayesem View Post
    Mate, I'd just call that luck to be honest.
