Results 1 to 2 of 2
Thread: high beam not working help needed
    vn ss
    Feb 2010
    Default high beam not working help needed
    hi guys my high beam dont work on my vn ss!!! ive checked globes, indicator stork, fuses relays etc and no go!! i have no power at any of the relay pins either......any suggestions??? oh also does anyone have a headlight wiring diagram too plz???
    VN S series 1
    Jan 2011
    Mackay
    I had a similar problem mate with my vn s my hi beams kept popping the 20 amp fuse underthe bonnet turns out it was the power wire coming from the relay for my high beam globe was being earthed to the metal suurround inside its sealed cavity.
    have you had a look at this wire?
    check if this wire hasnt had the unsulation squashed and earthed, it might explain the fact that its not working???
    let me kno??
  1. how to switch from high beam to low beam?
    By Shogun in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-11-2009, 12:34 PM
  2. High Beam/Parkers work, Low beam doesn't?
    By 003KWK in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-11-2009, 05:15 PM
  3. Low Beam Off When High Beam On?
    By Ozzie in forum Electrical Wiring / Questions
    Last Post: 19-05-2009, 05:16 PM
  4. high beam not working
    By SexGod in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-04-2006, 05:12 PM
  5. High Beam lights glowing when on low beam ?
    By Madhouse_Dave in forum Electrical Wiring / Questions
    Last Post: 03-09-2005, 10:15 AM
