Results 1 to 16 of 16
Thread: vn will start from strarter motor but not from ignition and no dash
    vp ss
    May 2011
    cairns
    Default vn will start from strarter motor but not from ignition and no dash
    i tryed all fuses really terminals coil alternator and still nothing
    mischa's Avatar
    mischa is offline <- 245rwkw Holden V8
    VN V6 T5 - 355 VN GRP A REP T56
    Jun 2005
    Ashbury, NSW
    I got know idea what your trying to say. What car? Engine? Whats happaning precisely?
    Quote Originally Posted by keza87 View Post
    Really who wouldn't want to give Jack a good smack in the back of the head.
    The Daily VN T5V6
    355 VN GRP A REP
    vp ss
    May 2011
    cairns
    well on the dash there is no lights no stereo nothing then tryed to start it but nothing so i by passed it by the starter motor and it strarted i look at all the fuses and realey switch and terminals
    it a vn v6
    mischa's Avatar
    Jun 2005
    Ashbury, NSW
    What do you mean i by passed it by the starter motor? To me that means you took it out/unwired it?
    Sounds like loose battery terminals, mine would do the same when i had shit clamps on them. Worth a shot.
    The Daily VN T5V6
    355 VN GRP A REP
    Dec 2009
    your shorting out hte starter motor terminals and the motor cranks but does not actually start and idle right? It should not actually start and run unless you do this with the ignition turned on.
    I you have no tell tales etc it sounds like a fuse or a fusable link so have a look at al of these if you can, take them out and use a multimeter. There are fusable links near the battery and the middle one is bolted in is the direct feed fromt he battery so it's probably OK also it's easy to crack the black plastic body doing the bolts back up so leave it alone if it has power on both sides just check the ones that pull out and the fuses under the dash.
    vp ss
    May 2011
    cairns
    cool will have alook but pretty much tryed all those what i meant by bypass is tht i started it from the strarter motor not the ignition thanks anyways
    Dec 2009
    VP Commodore S2
    May 2011
    vp ss
    May 2011
    cairns
    u put the screw driver in the starter motor a cross it and it starts and just found two grey wires coming from the ignition that arent even connected cant find were they go but i think it for the stereo
    db_notso's Avatar
    db_notso is offline diagnostic technician...
    vt v6, mods(susp brakesetc...)
    Oct 2010
    sunshine coast, qld
    battery isnt flat and starts when bridging signal and power on the starter?
    that starting sytem sure aint working correctly ~!
    pull the barrel out (key in turn on and pull barrel out by pressing in the hole on the coloumn)
    pull the ignition switch out
    turn igntion switch with screw driver
    my guess the point on the end of your ignition barrel is snapped off.... but car should not start and idle without the ignition switch on unless you hot wired the car... and the fuel (vn naughtiness) !~
    vp ss
    May 2011
    cairns
    yeah that what i did pulled the ignition barell out and try that and nothing so i put it on acc and started it at the starter motor
    db_notso's Avatar
    Oct 2010
    sunshine coast, qld
    wow.. then no dash lights no ignition circuit.... vn.....
    hang on ill check my crapola
    db_notso's Avatar
    Oct 2010
    sunshine coast, qld
    http://forums.justcommodores.com.au/...373-img333.jpg
    here is picture of engine power supply's from battery showing fuses what you need to pay attention to is the top part battery to ignition switch..
    and if check engine lamp doesnt illuminate when ignition switch in on position
    then likely no power to ignition switch from 60 amp fuse from battery
    or the battery earth is rusted or loose on battery or chassis
    or positive terminal loose
    basically diagnose why you dont have power supply to the dash from your battery when ignition switch on
    this will fix your problems...
    so yeah i guess its a fuse 60 amp from battery or ignition switch or battery terminals...
    vp ss
    May 2011
    cairns
    vp ss
    May 2011
    cairns
    db_notso's Avatar
    Oct 2010
    sunshine coast, qld
    good to hear~!
  1. VS ignition barrel broken. Need to start her.
    By moondog450 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-04-2012, 10:59 AM
  2. VX Broken ignition switch, wong start
    By Fuzzypumper in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-07-2011, 11:09 PM
  3. Replaced entire ignition system, still cant start on LPG
    By HyperThinker in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-01-2011, 11:55 AM
  4. Ignition problems... my car doesn't start flush... help !!!
    By bernie85 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-02-2009, 04:30 PM
  5. Ignition problem, Key wont start car.
    By tattoowrx in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 15-02-2009, 06:58 PM
