Can any1 help me find the hw 2 guide 4 fixg your own fuel pump or a manual.
1. Remove pump
2. Throw it at the neighbours dog
3. Install new pump
HW 2 install the fuel pump.
Get a hold of a Gregorys or Ellerys manual for your vehicle.
Good auto parts stores will have them. Best thing you'll buy.
Do a search on here, you will find plenty of info on how to do it.
Its pretty simple, de-pressurise fuel system, remove hoses and wires, remove sender unit, replace pump. Then the oposite for install. First one i done all i had was JC, no books.
The Daily VN T5V6
355 VN GRP A REP
drain tank
undo 5 bolts holding pump unit in
pull unit out
change over pump/unit
put unit back in hole, mind the baffles
screw bolts back in
Put petrol in
Vroommm
