Results 1 to 4 of 4
Thread: VN Series 1 V6 Manual Conversion
    VT Series 1 Berlina Wagon
    May 2010
    Croydon, Vic
    Default VN Series 1 V6 Manual Conversion
    Okay so i know a lot of info is going around about doing this. but i wanna know what other people have done or if they have any advice
    Short of finding a reliable series 1 t5 in decent condition, i know their are plenty of series 2 or 8 bolt boxes going around
    have people had luck with the crack adaptors?
    Has anyone been able to source a new 6 bolt flywheel?
    Any advice or comments would be useful as i plan on doing this conversion in the next few months.
    Cheers,
    Jack.
    2x 97vts and 2000 wh
    Feb 2011
    boxes are the same its the fly wheel thats different and yes i know this as i converted my old vn from auto to manual and used a vp gear box. you will have to bridge the neutral starter switch easy job to do some gear box places even have a plug that does it for you. you can still run an auto ecu as i did for 2 years with no issues at all its only you can not use a manual ecu on an auto. to get the pedal out you will have to pull the drivers side air con vent out as it just makes the job a hell of a lot easier and with the series 1 you have to change Ur motor to a manual motor as the auto and manual motors are different. the conversion took me about a day its not to hard just need to use your brain.and will also need a manual tail shaft.
    mischa's Avatar
    mischa is offline <- 245rwkw Holden V8
    VN V6 T5 - 355 VN GRP A REP T56
    Jun 2005
    Ashbury, NSW
    I used the adapter, been 3 years since i done it and its still fine.
    The complete Vn-Vr Manual Conversion Guide.
    Quote Originally Posted by keza87 View Post
    Really who wouldn't want to give Jack a good smack in the back of the head.
    The Daily VN T5V6
    355 VN GRP A REP
    May 2004
    I got a 6 bolt from the rod shop years back
  1. [SA] VN Series 2, VP and VR Manual Conversion For Sale
    By social in forum Parts And Other Items For Sale
    Last Post: 08-01-2011, 10:47 PM
  2. [SA] VN Series 1 Manual Conversion For Sale
    Last Post: 01-01-2011, 05:58 PM
  3. VR Series 2 manual conversion questions
    By grantmu1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-11-2010, 11:22 PM
  4. VS Caprice Series 1 Manual Conversion
    By jones-84 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-04-2009, 10:44 AM
  5. VN V6 series 1 Manual conversion parts
    By potshots007 in forum Parts And Other Items For Sale
    Last Post: 15-03-2008, 10:35 AM
