Results 1 to 3 of 3
Thread: Fuel Damper?
    dans_vz's Avatar
    dans_vz is online now formerly vp_berlina
    05 VZ V6 Exec & 92 VP Calais SII V8 Manual
    Aug 2006
    Albury/Wodonga
    Default Fuel Damper?
    Do I need a fuel damper on my VP V8? I notice that in the gregorys manual there is a fuel damper on the fuel line but I dont have one at all on mine?
    vs commodore
    Oct 2009
    Tamworth NSW
    If the factory fitted them, then it probably needs one..There would have to be a good reason why they fitted them in the first place..
    vr8-mafless, thats right mafless
    Feb 2012
    nsw
    on a vr v8 the damper is located on a bracket on the cylinder head as part of the fuel supply pipe just before the fuel injection rail. It is a can with an inlet pipe and an outlet pipe. You can blow straight through it. So what happens when it is removed? I took mine off for a while and felt no difference at all (took it off as I could not buy new bent fuel hoses that would fit it when the original 20 year old hoses finally gave up). Put it back on a month later and could tell no difference (and I run a 355 with 890 injectors so it sees plenty of fuel going through it)
  1. have had to wack the fuel tank to start my car!! is my fuel pump stuffed?
    By CV6Z in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-08-2010, 04:13 PM
  2. VX Strut top (damper top support)
    By MrSirWantalot in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-07-2010, 09:51 PM
  3. fuel damper adjustment
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 05-04-2007, 09:52 PM
  4. leaking fuel damper and fuel pump adventures
    Last Post: 18-08-2006, 04:00 PM
  5. EFI 202 front fuel damper...
    By KBone in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 21-10-2005, 10:45 PM
