Results 1 to 9 of 9
Thread: Fixing a Trip Computer
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Default Fixing a Trip Computer
    If you need to replace the LCD screens in a Level 3 trip computer - one major problem can be the white plastic fascia snapping the mount holes.
    Here is a way to fix it if you have most of the bits rattling around in side still.
    1. Take the trip computer out of the cluster and flip the screens over and remove the 6 screws holding the PCB onto the fascia.
    2. Remove the 3 LCD screens after marking them L - left m - middle - r right.
    3. Super glue the small parts (only use small amounts of glue here) back in place taking care not to get any in the threads - your just looking to hold in place at this point
    4. Cut 4 thin strips of 25mm sticky tape about 5mm wide and cover the 4 holes along the bottom of the fascia.
    5. Mix some 5 min araldite - about a 20c worth and using a strong type tooth pick place the glue in and around the holes in t steps. First put glue in all 4 spots and push down into the slots. Then as it sets make sure all 4 mounts are coverd at the top
    6. Within an hour you will need to trim the glue with a sharp knife/ofler blade so that the LCD screen fit back in. Also remove the sticky tape from the front of the holes.
    7. You then repeat for the top 2 mount holes with small aount of glue so that the glue joins the mount peg to the sides for extra strength.
    8. Trial the LCD screens for fitment and put the 6 screws back in. Some times the alignment is not so good and may need to repeat this step if screens are pale. If after several goes the LCD screens may infact be dead.
    9. If you get a screen with no segments at all you may have put it in upside down.
    10. I recommend running T4 Neo Wedge LED's in place of the globes to reduce heat. They are much cheaper to buy also.
    Also you can use this thread to ask any questions about trip computers or LCD screens you may have.
    Attached Thumbnails Attached Thumbnails Fixing a Trip Computer-busted-bits.jpg   Fixing a Trip Computer-some-super-glue.jpg   Fixing a Trip Computer-looking-messy.jpg   Fixing a Trip Computer-middle-holes-too.jpg   Fixing a Trip Computer-should-get-.jpg
    and 3 Dangerous non ABS VN's
    88GreenVN's Avatar
    Jun 2006
    Some times the missing segments are from the broken fascia and some times the LCD screen is dead (missing segments). I've not found a way to fix the screens as yet and so far the only way to go is to replace the screens with a known good ones.
    car
    Jul 2006
    greensy, melb
    good write up, should be a sticky or in the how to section, also left some rep for ya
    "A life lived in fear is a life half lived"
    88GreenVN's Avatar
    Jun 2006
    I missed a small part out - you will need the front part of the mount tab in place as this part is where the screw hold on (see the second photo). If the back part is missing you can cover with tape before adding the glue and the screw will still hold. You just need to make sure the hole has no glue in it. If for some reason glue gets in the hole you need to run a screw into it to make the thread good and let it set. The screw should come out OK when the glue has set.
    88GreenVN's Avatar
    Jun 2006
    I'll post up the 3 versions of the LCD screens.
    1. VN VQ Series 1 screen has the thin numbers and is prone to bleeding. (1st photo)
    2. VP VQ Series 2 screens with thick numbers and darkish background - prone to losing segments (need to find good photo)
    3. VR VS Series 3 screens with thick numbers and more silver background - also prone to losing segments (2nd photo)
    Attached Thumbnails Attached Thumbnails Fixing a Trip Computer-vn-vq_s1_lcd.jpg   Fixing a Trip Computer-vr-vs_s3.jpg
    wrx884's Avatar
    wrx884 is offline WA's ASR Rep
    VT Commodore Exec/5L VP Calais
    Mar 2006
    Hey shane just curious, with the LCD screens that have the more darkish backround vs 1 with a more silver backround, would this vary certain colours 2 shine through after the filter is removed? Ive noticed wen i did my own LCD screens white they turned out a more off white colour so i went back 2 blue 2 over come this, but if i had 1 with a more silvery backround could that possibly correct that?
    Check out my ride in progress.... 98 VT V6, V8 Supercar kitted
    Daily toy.... 92 VP Calais 5L
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by wrx884 View Post
    Yes the VP LCD screens are a little dark. the silver ones are 2 shades brighter and worth fitting. Green LED's are OK on the darker screens tho.
    wrx884's Avatar
    Mar 2006
    Cheers 4 the handy info shane i'll keep that in mind wen the VN-VS conversions start can u get a hold of the more silvery LCD screens urself if they r needed from time 2 time? may even grab myself a set 2 try again.
    could this also apply with the climate control LCD screens through out these models? tho i can make mine nice n white as it is but if u can make it cleaner again well thats even better, sorry 2 take it off topic lol.
    88GreenVN's Avatar
    Jun 2006
    Just repaired 8 of the fascias and fitting them to trip computers with dead LCD screens. I'll be selling on Ebay shortly if any one is after one.
  1. Resetting your computer and trip computer special functions (VT - VX)
    By Darren in forum Holden Commodore How-To's
    Last Post: 19-01-2011, 07:05 PM
  2. trip computer/total distance computer STOPPED!
    By Juzzy21 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-01-2007, 10:10 PM
  3. fixing the odo/trip
    By VL Berlina 5speed in forum VL Holden Commodore (1986 - 1988)
    Last Post: 31-07-2006, 10:52 AM
  4. The Trip computer
    By soulyouth in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-09-2004, 07:37 PM
  5. Trip Computer
    By daggett in forum Electrical Wiring / Questions
    Last Post: 22-09-2004, 08:01 PM
