Just bought A VN 91 and wondering is Brake light Top or Bottom and It has rear window one aswell....As Top and rear window work only...Thanks
Thays the way my vn was also. I think the early vns had all the red lights as break lights tho
there should be 5 brake lights top of the lights bottom of the lights and the window light
VN White Berlina Sedan V6 (S1) Full Lukey Exhaust Lovells Springs 15x7 Interceptors v8 Throttle Body Custom Tune Calais Grill Mulberry Calais Seats 2 12Inch Alpine S-Type Subs Level 3 Cluster.
before the adr came in for a high mount rear tailight vn's had all four light top and bottom i beleive after the adr they changed to the way vp's are which is top 2 and high mount brake light
Originally Posted by Smidy
my vn s1 had all 5 and my vq s1 has all 5 and my vp s2 had all 5
Yep, as people have said tail lights are lower 2 and top 2 are brake/tail lights. Of course that doesn't include the parcel shelf brake light
I reckon it would be better if only two were tail lights and all 4 for brake. Greater difference.
I also wish they would make LED replacement brake globes legal seeing they come on instantly, not 1/10 second later.
Why aren't they legal? Is it because the red of the LED doesn't match the red of the plastic lens?
Pub247 and alpha_au are correct. All the globes stayed double filament though.
I think that the LED's aren't legal because they don't meet (or simply haven't been tested to meet) requirements for visibility at an angle to the lens.
Thanks everyone..now i know...Top two brake bottom None.....Cheersss
Actually i think you misread, I'll make this as plain as i can
For Brake illumination:
VN= all 4
VP= top 2
With parkers and headlights selected ON:
VN + VP use all 4 (on the low voltage part of the globe)
I hope this clears things up
Its the VN Executive 91 and just found the manual book which says top 2 brake/tail...with high mount brake light.....bottom 2 just tail...and thats the way they work...So lets hope there right """" And yeah bottom 2 globes are double filament aswell....dont understand that...Anyway Thanks too all![]()
VN = all 4 brake, have a look at the difference in the VN to VP looms, if you have a VN and it only has 2, chances are you have a VP loom, if your manual says only 2, your manual is wrong![]()
The VN handbook shows that theres supposed to be two stop/tail lamps each side-1 top and 1 bottom, as well as the rear window brake light..These taillights use duel filament bulbs,which are 21w for the stop lamp and 5w for the taillight.These bulbs have different spaced holding pegs so a normal single filament bulb will not fit.(Ive seen the single ones just jammed in there before though,I guess some people just have no idea.)
Ok just had a look at the wiring The Top has 3 wires and the Bottom has only 2.....any ideas
you have a VP loom...
From 21/12/1990 Tag Number L484423 SINGLE LEVEL STOP LAMPS USED FITTED WITH HIGH LEVEL STOP LAMP
and 3 Dangerous non ABS VN's
All cleared up now i think....Thanks
either way just wire them up so u got all 4 brake lights working. ive done this in the VP looks much better and 4 piece of mind, more brake lights the better i say![]()
So.... if you had your VP wired a la VN with 4 stop lights and just say only 3 were working and you got pulled up, even though you were required to have only 1 per side I wonder how you would go :-)
woudnt think ud have any dramas wen u should have the rear mount brake light also or a spoiler brake light so thats 5 in totalbut i cant say if heard or seen ppl pulled over 4 brake lights unless either the rear mount and another whole side wasnt working. then again im in perth
Just another of the many running model changes
