Results 1 to 5 of 5
Thread: Shooshing induction noise on V8
    VP Executive 5L
    Mar 2011
    Default Shooshing induction noise on V8
    Everyone that drives a VN or VP V8 knows that when you give it a bootfull, particularly if you have a quiet exhaust, then you can plainly hear the roar of the air pulses being sucked into the engine making a real racket. I suppose the ideal solution would be to have a rigid, non-flexible airbox and a tuned length of tube coming out of it for the air to go in. Same deal as a stock air cleaner housing on a carburettor. Even the same deal as a subwoofer box and port tube. A Helmholtz resonator if you must.
    Helmholtz resonance - Wikipedia, the free encyclopedia
    Has anyone here ever mucked around to see what can be done to tame this source of noise?
    Jonno's Avatar
    Jonno is offline :)
    Nov 2010
    Vic,
    guessing u dont like induction noise?
    why not just do what ford and Mitsubishi and many other car companies do and get a pipe added ontop so the air and ...wait ill get a pikk
    ok u see where the pipe goes into the engine.. and theirs that big box sitting onto of the engine
    the air goes into that before it travels in and it silences the intake
    Quote Originally Posted by Rufys View Post
    yup! I think I might actually be gay
    savage1987's Avatar
    savage1987 is offline fail champion
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    VP Executive 5L
    Mar 2011
    Okay. Just for a start I might see if I can add a length of inlet pipe to the airbox and see if that helps. Might even use it to draw in cold air too. Airbox is pretty flexy so maybe a slab of something thick glued to the outside flat surfaces would be the go.
    The whole idea is to not attract attention when I give the car a bit of a squirt.
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    Cold air intake quiets mine down allot, when I take it off for more noise I can hear it sucking because of the enlarged hole
  1. Induction Noise
    By Homer's HSV in forum VE Holden Commodore (2006 - ?)
    Last Post: 02-01-2011, 06:58 PM
  2. Strange Induction noise? - 4th and 5th gear only
    By timmo666 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 15-10-2010, 11:24 AM
  3. should i be getting an induction noise from my cai?
    By pillzor in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-07-2009, 05:20 PM
  4. induction noise?
    By jazzawithvg38 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-11-2007, 02:37 PM
  5. not as much induction noise
    By chevy_big_block_bro in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-11-2005, 07:44 PM
