Results 1 to 18 of 18
Like Tree1Likes
  • 1 Post By VNVacationer
Thread: Penrite; is it the go?
    S2 VN Wagon Exectuive
    Apr 2011
    SOUTH EAST GIPPSLAND, VICTORIA.
    Post Penrite; is it the go?
    Got a VN With reco engine with about 200,000 - 250,000 K on the clock.
    About to do a service and change a few other things under the hood.
    I've scoured through the forums and find about an equal amount of arguments FOR and AGAINST using what I have summed up possibly the best cost price and value oil for me:
    PENRITE HPR10 10W / 50
    Some say using this in their commodores has made it run like a dream, whilst others claim it has made their car louder on start up, and hence have changed to Valvoline or another brand.
    Any assistance?
    VP Calais Series II V6
    Jun 2009
    Quote Originally Posted by Scheme View Post
    Any assistance?
    I just did a service on my Calais this weekend, filters, spark plugs the lot of it. I bought some Valvoline Max Life which I have used before. Although my Calais only has 113,000, the Max Life I bought before was good and I havent noticed anything different since changing it. I would also suggest you get some engine detox to get all the crap thats left in the engine (I used Liquid Moly Engine Detox) and maybe even some fuel injector cleaner, just to get it going alittle better. I have heard some good things about Penrite oils (and some bad). Ive never tried it myself, but give it a go and see how it is.
    dirt drifter's Avatar
    dirt drifter is offline white trash hillbillie
    VS 5L M5 VS 6L M6
    Apr 2009
    massive hole in the ground
    i cant comment on the viscosity of the stuff you're looking at but i've run penrite HPR30 in my 5L's ever since i had a licence, changed every 5000k's.
    many people seem to recommend it and i've had no dramas at all with it
    Quote Originally Posted by UFO View Post
    worked v8 + supercharger + dogbox = panty moistening equipment.
    4 banger turbos with bov's will just cry when they hear it, because they can never have it.
    Quote Originally Posted by GRPABT1 View Post
    Avoid cluey police
    vs commodore
    Oct 2009
    Tamworth NSW
    For a few years now Ive used the penrite semi synthetic HPR 15,which is a 15W-60 oil.It exceeds the manufacturers recommended specs of 20W-50,its a bit thinner at cold startup,which means the oil gets up into the engine faster when its first started from cold.And then on the other hand, it also stays a bit thicker at high temps, so it gives you better protection in the high temps of the aussie summers.Its not very expensive either,around $30 for 5 litres.Id recommend it to anyone wanting a good oil for their V6..I have recently changed to mobil 1 oil now which is a full synthetic oil...
    Apr 2011
    Thanks for the info guys, starting to get a bit more direction now, I reckon I may give it a crack.
    The book states 10W / 40 for the VN, now over 20 years old, I live in Gippsland in victoria, it's pretty cold here, and might as well not have even had a Summer for 2010/2011... So I'm assuming the 10W / 50 Penrite semi synthetic should do the trick and if need be on the next change go to full synthetic perhaps. I just want something thats under $60 for 5 litres, and will protect my engine and make it run efficiently hence reading the specs of HPR10
    vx berlin series 2 2002
    May 2011
    hillside
    Hi Scheme Penrite is okay dont get caught up in that expensive crap its only a waste of money oil companies want you to buy. The oil repco sells as its own is penrite as long as you change regularly,most brands are okay $25 - $35 should get ya a good oil,cheers.
    Apr 2011
    Possibly now thinking HPR15 as many have said that over the HPR10 as it '*Semi-synthetic engine oil formulated primarily for use in "older" engines
    *Suitable for use in pre 1997 Australian family cars'
    VP Commodore SS 1992
    May 2011
    Auckland NZ
    I really like the valvoline VR1 mineral racing oil, its around 50 in NZ and has one of the highest zinc contents in it.
    Jonno's Avatar
    Jonno is offline :)
    Nov 2010
    Vic,
    i run penrite hpr30 in my 202 and my vk loves it
    might as well give penrite a go?
    Quote Originally Posted by Rufys View Post
    yup! I think I might actually be gay
    VR V6 turbo 4speed
    Sep 2007
    coffs harbour
    i use HPR10 in my VR. never had any issues and it was absolutely flogged. when i broke the timing chain and had it apart, was still spotlessly clean inside. no sign of gunge or sludge anywhere.
    another positive note,(a year later) the engine was sitting under a plastic cover that must have leaked coz the sump had about 2L of water in it, and the oil that was still clinging to the underside of everything was enough to stop it rusting.
    basically the moral to that story, penrite also has Klingon properties... much like Magnatec.... good for those worried that theres no oil where it needs to be after being left to sit.
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    I have used penrite for years in my last 3 cars (uc torana 202, VL 3.0 and now VN 5 litre), always run great never broken anything and oil is in good condition when I change it every 5k or so.
    Vn Vacationer
    Jan 2007
    Whatever you decide just make sure you do regular oil changes and this will keep the motor in good nic for years
    VS Equipe
    Jan 2011
    Adelaide, SA
    I have always run Penrite full mineral oil (I won't use Synthetic on old engines)
    I have run it on my subaru for its entire 600,000k and never had an issue.
    Both my cars have over 300,000 on them and I have never had a major component fail, which I think is partly due to doing a complete oil/filter change every 5k on the dot
    Top notch oil :P
    96' VS Equipe (Current Project/Weekender) (CLICK HERE)
    Resident VR/VS Addict
    vn calais 5.0
    Jun 2011
    victoria
    I use mobil oil and alway happy with it.. Did the wifes car last week ad put the motor oil flush stuff in and ran it for 10 min at idle and drain oil and filter and fill up..
  15. #15
    97VT SS super6,daily 05 holden barina(opel)!!
    May 2009
    I switched over to penrite years ago and never looked back,my car has 210k on it and runs like a dream using 20W/50 on my super6..plus its a decent price aswell
    Also check my ride,sitting on HSV R8 19's
    " And on the Seventh day ,GOD created Commodores!!!! "
  16. #16
    Apr 2011
    Serviced her today and threw in some Penrite HPR15, she runs a treat now! Think I'll be stickin' with this! Thanks to all!
  17. #17
    VP Vacationer wagon
    Feb 2006
    Took my intake off after 350 000 kilos and the inside was spotless, clean enough to eat from. I ran castrol for the first 350 000 km but have now switched to penrite 20w50. no problems.
  18. #18
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Penrite is an excellant oil enough said.
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
  1. penrite oil
    By madsav in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-05-2011, 09:25 PM
  2. Penrite GAS oil..
    By VN Lukey in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-08-2009, 01:26 PM
  3. Penrite oil issue
    By mr_clubby96 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-12-2008, 04:00 PM
  4. Has anyone used Penrite ATF Fluid and Sin ATF
    By vxcalais_01 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-07-2008, 02:01 PM
  5. Penrite Gas 10
    By andyli in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-02-2007, 08:47 AM
Tags for this Thread
