Results 1 to 12 of 12
Like Tree2Likes
  • 2 Post By wraith
Thread: Make power steering lighter?
    VP Executive 5L
    Mar 2011
    Default Make power steering lighter?
    Is there any way to make VN/VP power steering lighter? Some kind of adjustment? I want to be able to steer with one finger.
    VY Executive S2/ VY SS 6sp
    Jan 2011
    Western Australia
    get hold of a vp calais system they are 1 finger stering (unsure if it is a different pump or rack)
    wraith's Avatar
    wraith is offline Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    Err why do you do need to be able to steer with 1 finger o.O Are you handicapped?
    VP Executive 5L
    Mar 2011
    I don't need to - I want to :-)
    After I get out of the missus' Camry the VP feels like a truck.
    I just like the idea of not having to wrap my fingers around the steering wheel, just wind it around with the palm of my hand.
    I don't care nuthin about road feel; I don't drive fast around corners. Straight roads are my thing. Curvy roaded housing estates are pesky.
    Years ago a mate had a 1958 Jaguar. You could tap the steering wheel and it would rotate lock to lock like the steering column was cut. THAT was cool.
    wraith's Avatar
    '95 VR Series II
    Sep 2008
    Demonicaland
    I have driven a few VN's and the power steering as always been easy enough to wind around with a palm as you say. Maybe check your fluid levels and make sure your rack isn't leaking.
    nathanVY's Avatar
    nathanVY is offline need boost...
    03 VY Calais, 99 VT Equipe
    Dec 2009
    Geelong, VIC
    Calais have variotronic steering racks, so yes the rack is different. Not sure if there is any other differences
    Big difference from an exec to a calais though
    VP Exec
    Jun 2005
    In addition to the rack and the BCM to control it (the variable part) the outlet on the pumps are different but interchangeable (there is also a spool and spring inside the standard pump outlet which has to be removed with it).
    A Calais/Statesman rack and pump outlet, without the BCM, would give very light steering at all speeds. There may be a way to later the weight without the BCM as it's only a PWM signal.
    VP Executive 5L
    Mar 2011
    Actually the pump is a little bit noisy. When they start to wear out does the available pressure drop and cause the steering to get heavier?
    wraith's Avatar
    '95 VR Series II
    Sep 2008
    Demonicaland
    Given the age of the vehicle if it hasn't had a new pump put in wouldn't surprise me. Same goes with the rack. Notorious problem.
    MasterOfReality's Avatar
    MasterOfReality is offline Thats Dr to you.....
    VP HSV Enhanced Calais, 2006 Suzuki Grand Vitara
    Feb 2004
    Where the mines are
    Yeah the pumps do give issues which results in no power steering.
    Strangely enough its fixed by removing and replacing the fuel pump relay
    VP Executive 5L
    Mar 2011
    In the p/s box of my HJ it had sort of springy, twistable valve and the harder you had to turn the wheel the more it twisted and the greater the amount of pressurised fluid it let through to give assistance. How does the rack I have got work?
    VP Exec
    Jun 2005
    Same way, only the twisty bit is in the 'rack tower.
    If you want to experiment, maybe try to find the VP Calais/VQ SII Statesman pump outlet at a wrecker and swap it over (assuming that your current pump is OK and not as described ^^).
    It will up the pump pressure so will be harder on the 'rack seals so be prepared for the possibility of the rack leaking.
  1. Ugh.. VT Cigarette lighter/Power Source..
    By bpottz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-09-2009, 07:46 PM
  2. Can you make the clutch pedal lighter
    By JA2Z in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-07-2009, 05:51 PM
  3. VX SS - No Power From Cigarette Lighter
    By nolim8ts in forum Electrical Wiring / Questions
    Last Post: 03-11-2008, 02:56 PM
  4. Can you mod the power steering to be lighter?
    By ascension24 in forum General
    Last Post: 13-12-2007, 11:19 AM
  5. cig lighter to power my head unit?
    By phat_com in forum Car Audio
    Last Post: 03-12-2006, 03:19 PM
