Hey guys I just brought my self a vp factory 5 speed n when I tried to jump start it I melted the earth wire from tha battery to the side of the engine bay near the headlight, is there any reason why that would of happened?? I'm 2 scared todo it again![]()
1993 VR CALAIS 5 SPEED MANUAL,Lowered all around on pedders, 20 inch G8s, Option audio front splits, option audio amps, sound stream subs, pace maker extractors, high flow cat, 2.5inch lukey cat back exhaust
i would guess you put the positive on the negative and negative on the positive, e.g jumper cables backwards...![]()
Na all was done right, it only started to smoke when it actually started
Most car have a skinny black wire going to the body and a fat black wire going to the engine block.
My guess is the fat wire is not making a real good connection to the block so all the current goes through the skinny wire, so it ends up smoking.
yep a crappy earth will do that check your earths. I had the same problem i just got some 4g amp wires and made a new earth on the body and havent had a problem since.
VN White Berlina Sedan V6 (S1) Full Lukey Exhaust Lovells Springs 15x7 Interceptors v8 Throttle Body Custom Tune Calais Grill Mulberry Calais Seats 2 12Inch Alpine S-Type Subs Level 3 Cluster.
