Results 1 to 7 of 7
Thread: Level 2 VP Cluster
    S2 VN Wagon Exectuive
    Apr 2011
    SOUTH EAST GIPPSLAND, VICTORIA.
    Post Level 2 VP Cluster
    Bloke at the wreckers assures me this will work for $70. But he's well known in town for being a dodgy bloke.
    After reading a bit on the forums, I will just make this simple.
    I have 1990 VN Executive. With Cruise/Antenna control & A LEVEL 1 Dash Cluster, as simple as they come.
    This is the exact one I'm being sold:
    Recovered from a VP Berlina.
    Will it work?
    Thanks!
    vp calais, vn calais, vp berlina all 3.8 litre
    Aug 2008
    Pascoe Vale South, MEL
    think there different dude not sure that one will plug right in and work. ive got a vp berlina and a vn lexcen they look totally different from the back... hit up 88greenVN if you dont get any replies.... hes the authority on this stuff...
    matty94's Avatar
    matty94 is offline Addicted 2 VN's
    Vn Berlina
    Apr 2011
    Dandenong area S.E VIC
    should work if its same engine (v8 wont reed right in v6) just take the old one out and put the new one in or if you want to keep your original ks just convert your s1 cluster to a s2.
    VN White Berlina Sedan V6 (S1) Full Lukey Exhaust Lovells Springs 15x7 Interceptors v8 Throttle Body Custom Tune Calais Grill Mulberry Calais Seats 2 12Inch Alpine S-Type Subs Level 3 Cluster.
    matty94's Avatar
    Vn Berlina
    Apr 2011
    vn vp L1 L2 are the same only going to L3 clusters you have to add a plug. vp berlinas have L3 thats why its different.
    Apr 2011
    Ah fair enough then, I may go to the out of town wreckers and ask him instead, if I can scower through the many vps and vns he has there and grab one off him.
    Cheers for that, otherwise throwing this in the V6 may have been a bad move!
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Quote Originally Posted by Scheme View Post
    Will it work?
    Thanks!
    The photo is a VP L2 cluster - it should also have a sticker on top that starts with a K.
    3 Warning lamps are wrong from memory and you may need to change 3 wires to get it to work correctly. Connector 1 the 2 brown white wires move over 1 slot and the blue wire to 9 or 10.
    and 3 Dangerous non ABS VN's
    matty94's Avatar
    Vn Berlina
    Apr 2011
    Fotgot warning lamps im preety sure they are differnt with warning lamps your best of just takeing it apart and putting the tacho and stuff in the L1 that way you can keep you original ks.
  1. Installing A Vr Instrument Cluster Into A Level 1 Cluster Vn Exec
    By badly_drawn_boy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-07-2011, 02:41 PM
  2. Vx Dash cluster level 2 into a VT with Level 3. is this posible ?
    By Madhouse_Dave in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-12-2010, 12:33 AM
  3. Strange things after changing from VN Level 1 cluster to VP Level 2
    By vsspack in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-03-2010, 09:45 AM
  4. Dropping Level 3 Cluster into unready Level 2 ready VS
    By VS Omega in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-01-2009, 03:56 PM
  5. VS Level 1 to Level 3 Cluster Upgrade
    By Luv holdens guy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-02-2006, 01:28 PM
Tags for this Thread
