Results 1 to 14 of 14
Thread: 5ltr missing on idle and load
  1. Unhappy 5ltr missing on idle and load
    Hey guys, long time no visit..
    I've got a problem with my VP 5ltr. It's missing at idle, and when I first take off it stutters pretty badly, and under load it stutters too, but cruising is fine. This problem has progressively been getting worse, at first it was an occasional miss, then missing all the time at idle, then stuttering when taking off, and now sometimes stuttering under load. Note that this happens on petrol and gas, so at least I know it's not a fuel problem. Plugs are new, I thought it might have been leads at first so I replaced them, but now the problems getting worse I'm guessing it's something else.
    Symptoms remind me of a failing coil. My coil is only about 1 and a half years old though, so I'm hesitant to buy a new one because mine should be fine. Any ideas of whether it could be anything else? Or has anyone else had coils fail so quickly? Considering the progression of this problem, if I keep driving the car whatever it is will probably die and in that case I'll have a better chance of figuring it out
    Thanks,
    Christian
    Quote Originally Posted by zai View Post
    I am not sutpid
    MasterOfReality's Avatar
    MasterOfReality is offline Thats Dr to you.....
    VP HSV Enhanced Calais, 2006 Suzuki Grand Vitara
    Feb 2004
    Where the mines are
  3. Default
    haha i think having 2 of the same car is the only cost-effective way to debug problems like this. alas, i don't want another 304. thinking of buying something like a polo gti
    I am not sutpid
    VP Executive 5L
    Mar 2011
    Could well be distributor cap or rotor button arcing over. The more often it arcs the greater the trail of carbon so the easier it subsequently arcs.
    Probably easier to switch cars than change cap and rotor :-P
  5. Default
    haha yeah, what a pain, but i might just have to start changing stuff over until it's fixed . makes sense though considering the progression of the problem getting worse. cheers! also, do you think it could have anything to do with vacuum leaks and/or the map sensor?
    I am not sutpid
    VP Executive 5L
    Mar 2011
    Probably not anything vacuum-related because as you say the problem gets worse the more you put your foot down. Putting foot down makes LESS vacuum so any leaks would then not leak as much as before.
    vn calais 5.0
    Jun 2011
    victoria
    might be the throttle position sensor.. Mine was sluggish and when you went to stop at the lights it would run ruff and cut out.. had to have 1 foot on bothe peddels to keep it running..
    Warranty Void's Avatar
    Warranty Void is offline Take it apart? Me? No!
    VP Berlina LX V8
    Sep 2009
    Dude I changed about 3 standard coils due to exactly those symptoms....got sick of it and bought MSD Blaster SS for 20 bucks more than standard, that was a few years ago now, best move ever. Have a look at my profile for pics of engine bay and coil placement, coil lead fit fine, wiring extended by about 30cm, half hour job.
    Warranty Void
  9. Default
    Quote Originally Posted by Warranty Void View Post
    haha, i had this weird feeling it was the coil but i just ended up second guessing myself too much . i gave up and took it to the mechanics today, they changed the spark plugs over from the ones i had in it (NGK BPR6EF, 3 weeks old) to genuine holden plugs and they reckon it's ok now... but i highly doubt it, i had the NGKs in it before, and it's unlikely that there was more than 1 bad new plug (and with the way the car stuttered, it couldn't have just been 1 cylinder playing up). i pick the car up tomorrow, if it's still shit i'm going to get an MSD Blaster SS and go from there
    I am not sutpid
    vn hsv wagon
    Apr 2011
    Frankston
    car
    Jul 2006
    greensy, melb
    Quote Originally Posted by brodster View Post
    AIR flow meter
    there is no air flow meter in these
    "A life lived in fear is a life half lived"
  12. Default
    bit of an update - got the car back from the mechanics, runs beautifully with the genuine holden plugs. pretty strange, and i don't really understand why the ngks were so bad (and why the problem was progressively getting worse), but meh i'll see how it goes and update if anything else happens.
    I am not sutpid
    car
    Jul 2006
    greensy, melb
    how old were the ngk plugs? cos maybe there was a bad batch or something as i just had a set stuff up on me too, replaced with a new set of ngk's and runs perfect
  14. Default
    i think i bought them about 6 months ago or so, had them sitting in the garage for a while until i changed them over . i've always used NGKs so i agree, maybe just a bad batch. perhaps the gaps were off as well, probably worth investing in a gapping tool for next time
    I am not sutpid
  1. VP V6 missing at idle and under load
    By vp-s in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-10-2011, 08:22 PM
  2. Missing Under Load
    By RoboticCherry-Coke in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-07-2010, 11:18 AM
  3. VN missing under load
    By sideshowjbomb in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-10-2009, 09:48 PM
  4. Missing under load
    By IBLOWN in forum V6 Development And Modification
    Last Post: 01-06-2009, 03:09 PM
  5. missing under load
    By vsII manual in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-12-2005, 07:33 PM
Tags for this Thread
