Hey guys, I have a vp commodore and the horn isnt working! I have tried most things I have found in threads but still no success. I was just hoping someone could tell me where the horn itself is actually located? I have tried searching and found nothing (in my car) so a location would be great! Thanks!
behind the bumper on the left side.
VN White Berlina Sedan V6 (S1) Full Lukey Exhaust Lovells Springs 15x7 Interceptors v8 Throttle Body Custom Tune Calais Grill Mulberry Calais Seats 2 12Inch Alpine S-Type Subs Level 3 Cluster.
yes thats where i sed behind the bumper on the left.
Thanks guys, Found it. Looks like it has seen better days before. If i run a positive and negative to the battery from the horn it should go off shouldnt it?
yep it will go off.
i swapped mine out with a set from a vt.... double horns
The horn switch operates from the steering wheel pad thing then through a sliding contact behind the wheel onto a brass buttony thing on a spring, the brassy thing wears out after about 10 to 15 years and you need to pull the steering wheel and put a new one in.
Warranty Void
You can get away with roughing up the end of the pin and dropping a blob of solder onto it, instead of replacing it. I've fixed alot of my own cars this way and they all still work
Ok I have pulled the wheel off, the brass pin seems to stick out a fair bit but does look fairly worn. I'll try the solder on the weekend and see what happens. Thanks very much guys!
