Results 1 to 6 of 6
Like Tree2Likes
  • 1 Post By agrsv8
  • 1 Post By Not_An_Abba_Fan
Thread: Rear end side to side movement
    VN SS
    May 2011
    New Zealand
    Default Rear end side to side movement
    Just noticed driving home the other night a dull thunk like something in the boot rolling around but I also spot side to side movement of the diff. Normally I'd put it on the lift and just shake the rear end a bit to find it but the lift is out of action
    My guess is Panhard rod bushings, common to go out and on the right track? I gotta have this thing to tow my racecar sunday so I may have to just deal with it till I have time to fix it right.
    VP SS, Cammed VN V6 daily
    Jan 2010
    any side to side rear end movement will be the Panhard rod bushings or the trailing arm bushings. Should be pretty easy to sort out, just jack up the rear and push the axle side to side, look for what has a bit of play
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    For the panhard rod bushes, you don't lift the car at all. Stand at a rear wheel and look down, grab the wheel arch and rock the car side to side, if you see the body move, the panhard rod bushes are worn and need replacing. About a 20 minute job.
    Visit my Facebook page
    VN SS
    May 2011
    New Zealand
    Quote Originally Posted by Not_An_Abba_Fan View Post
    That is exactly what it does, guess I should go on the hunt for a nolathane kit or something then, at any rate they will need doing anyway probably so eh.
    So anyone in NZ know somewhere good or do I actually have to start annoying contacts one by one
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Check the trailing arm bushes too. Upper and lower. Sometimes they blow out and fall inside themselves, causing the arms to provide NO lateral location. A car with a good panhard and flogged upper control arm bushes will still move side to side a fair whack.
    But most likely panhard. Easy easy job
    The 1972 HQ Kingswood
    VN SS
    May 2011
    New Zealand
    WOW the car handles a lot tighter now, made an unbelievable difference. You could almost swear I'm not driving a tank lol.
    PS yes that is all that was left of the bushing, the rest was literally gone, was not in chunks or in a seperate bit, it was gone totally.
  1. "Right hand side rack end has movement" - VN
    By PUSHIN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-02-2011, 03:01 AM
  2. Vt Wet Footwell... Rear Passenger side (Left Rear)
    By Puma in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-12-2010, 12:47 PM
  3. How to remove driver side button for side mirrors?
    By SupremeVT98 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 23-07-2009, 09:14 PM
  4. VL body 12mm lower on rear right side (drivers side)
    By ewan in forum VL Holden Commodore (1986 - 1988)
    Last Post: 09-03-2009, 02:07 PM
