Results 1 to 5 of 5
Thread: vn dip stick pipe white sludge
    vn 2l berlina but at least a manual
    Jan 2009
    nz
    Default vn dip stick pipe white sludge
    when i pull the dip stick out white sludge comes out with have been told this is because that part of the car is the coldest. the car now lives car shed and still has it does anyone know if this is normal or have been told wrong
    vs commodore
    Oct 2009
    Tamworth NSW
    When coolant gets mixed with engine oil it turns into that white slimey stuff you see on the dipstick,it may also be under the oil filler cap if you look.These V6 engines are well known for getting leaks in the inlet manifold gaskets once they get around 150,000 k's or more on the clock.Luckily these gaskets are easy to replace.They mostly seem to slowly start to leak at first,and the engine will still seem to run normally for a fair while before they start to get worse and ultimately,completely blow,so when they are at the first stages of leaking,it can be just enough of a leak to get some slime ,but not a real lot,then as time goes on,this white slime will slowly build up and increase more and more until its heaps noticable on the dipstick and under the oil filler cap,and the coolant levels will need topping up heaps more often.You can confirm the inlet manifold gaskets are leaking/blown by getting the cooling system pressure tested at a mechanics.Its also probably a good idea to get the engine compression tested and the hot and cold oil pressures tested as well,this will give you a good idea of the overall condition of the engine.These tests are fairly cheap to get done.
    304runner's Avatar
    304runner is offline ( .Y. )
    VR 5.0 Ute & a 4runner with a VS SS trasplant
    Mar 2011
    Central Coast NSW
    Either what he said or you have blown a head gasket.. Id head strait to an Auto shop and ask for a bottle of "Chemi-weld" and throw that in the radiator..It will clog up the leak and you can replace your oil...
    vn calais 5.0
    Jun 2011
    victoria
    how far do you drive the car? I have read and chatted to many people on bike forums about this.. it mainly happens on short drives cos the motor does not get hot enough to burn it off.. Take it for a drive on the hwy for a bit and then check again..
    VP Executive 5L
    Mar 2011
    PCV system could be blocked too. Normally, moisture from combustion gets past rings in to sump, PCV sucks it out.
  1. [VIC] Vx white venetians, vx gts maf pipe, stereo gear, hbd vx custom insert with gps
    By CHEETR in forum Parts And Other Items For Sale
    Last Post: 07-01-2011, 10:53 AM
  2. white sludge on radiator cap
    By carls vtss in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-10-2010, 04:19 PM
  3. FS:polished pipe/ twin pods-pipe
    By Joey_21 in forum Parts And Other Items For Sale
    Last Post: 07-09-2007, 06:25 PM
  4. Small amount of white sludge on oil stick
    By stmcomms in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-11-2006, 06:34 PM
  5. salesale - dump pipe, front pipe, high flow cat, catch can + more
    By venomous in forum Parts And Other Items For Sale
    Last Post: 19-08-2006, 06:20 PM
