Results 1 to 12 of 12
Thread: turning over slow, but battery fully charged
    vn commodore
    Apr 2010
    Default turning over slow, but battery fully charged
    hey guys I noticed the other day the car was turning over real slow, then it just wasn't at all so i thought battery must be flat because it had been sitting for a couple weeks. Checked battery its fully charged so not im confused. someone mentioned could be fuel pressure regulator but just want some other opinions?
    turmoil117's Avatar
    turmoil117 is offline Donating Member
    vn berlina, vr statesman
    Jan 2010
    Westminster
    vr commodore bt1
    Jun 2011
    The easiest way to fault the battery is to check the voltage at the battery whilst the car is being cranked over, anything under 10 volts the battery is stuffed. To rule out your starter motor being worn connect another battery into the mix with jumper cables and if it still cranks slow then it's your starter motor / wiring not the battery
    vn commodore
    Apr 2010
    checked water its all good, checked voltage when running getting 14.5v so im thinking possible starter motor but any other ideas?
    VS SS
    Mar 2009
    gday mate, i just fixed this very same problem on my vp v8, was the starter motor solenoid, the battery lead to it was loose and the plastic was brittle from the years of heat, so i removed the starter and replaced the solenoid and its good as new now, so check those things on yours, cheers and good luck.
    Hangman's Avatar
    Hangman is offline Torana Addict
    2 commys, 3 Toranas and a WB Panel Van
    Jan 2010
    Newcastle, home of Toranafest
    Check the voltage while cranking, not while running. If the above doesn't fix it.
    Quote Originally Posted by hakhawk View Post
    there are more pressing issues on the site, like choosing between vl's and potatos.
    Vr ss & vy v6 wagon
    Jan 2010
    Central Coast, NSW
    Quote Originally Posted by stockyvrcalais View Post
    my old vq v8 was the same,really slow to start and if the motor was warm was even worse,changed the solenoid and was good as new after that
    vn commodore
    Apr 2010
    hey guys where would ya get a new starter motor solenoid from? is this something supercheap might stock or will i need to go to holden for it? also whats the deal with the voltage while its turning over what am i looking for?
    VS Berlina soon to be 5L
    Aug 2010
    Girrawheen
    you get a new starter motor for 160bucks at coventrys, dont know if they sell just solinoid, but if it me just replace starter motor
    Vr ss & vy v6 wagon
    Jan 2010
    Central Coast, NSW
    had mine replaced at the local auto leccy for $50. that was with me taking the starter to him...
    Hangman's Avatar
    Jan 2010
    Quote Originally Posted by kinkyaz View Post
    Quote Originally Posted by noddycommodore View Post
    As Noddy said.
    vn commodore
    Apr 2010
    sweet cheers yeah missed that one ill give it a go today and see what i come up with
  1. oil in throttle body? and slow turning over
    By kinkyaz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-09-2010, 01:33 PM
  2. front suspension clunking when turning slow
    By tyson_georgie_vy_ute in forum VY Holden Commodore (2002 - 2004)
    Last Post: 23-05-2010, 10:22 AM
  3. vt slow turnover sounds like flat battery??
    By mojo.jojo in forum Electrical Wiring / Questions
    Last Post: 09-11-2009, 08:43 AM
  4. Not turning over properly - battery connection?
    By javt99 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-07-2008, 11:22 AM
  5. Battery getting fully drained. Need help!
    By sganro in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-06-2008, 07:25 PM
