Results 1 to 14 of 14
Thread: Cylinder 3 is not firing after washing motor
    VX Berlina Wagon
    Oct 2007
    Default Cylinder 3 is not firing after washing motor
    went to the carwash today to try and get rid of all the grease on the motor and now its runing like shit. unplugged the injectors 1 by 1 to work out which cylinder was missing and ive narrowed it down to cylinder 3. changed the spark plug, and changed the O-ring on the injector and still nothing. no error codes have come up.
    anybody got any ideas???
    vr commodore bt1
    Jun 2011
    Spray a bit of wd40 or what ever you have into the spark plug. It will get the water out. Check for sparking from that spark plug lead also
    Darcon666's Avatar
    Darcon666 is offline Evil is always around you
    The Wife
    Jun 2010
    At home
    VX Berlina Wagon
    Oct 2007
    vr commodore bt1
    Jun 2011
    Pull the spark plug lead off and sit it near a metal part of the engine where it won't move ( don't hold it!!!) there is enough zap there to kill a man. But then start the car you should see a spark or hear it zapping
    VP SS, Cammed VN V6 daily
    Jan 2010
    i can will tell you right now to change the coil pack and DFI module. I would even investigate spark. $$$ on it
    VX Berlina Wagon
    Oct 2007
    can you swap 2 coil packs around? or do they have to be used to their corresponding numbers?
    Darcon666's Avatar
    The Wife
    Jun 2010
    At home
    Quote Originally Posted by noddycommodore View Post
    ...............( don't hold it!!!) there is enough zap there to kill a man.
    First part correct and how to test, but this above is not possible... there are not enough AMPS in the coilpack(In a cars electrical system) to kill a human being, yes the VOLTS are high... it's amps that kill.
    Having said this if you are using a "magneto" to generate the electrical spark then they could kill an elephant.
    VX Berlina Wagon
    Oct 2007
    swapped the dfi and coils from my vx...fixed the problem....so the problem is either coil pack or dfi....thanks guys..
    vr commodore bt1
    Jun 2011
    Having said this if you are using a "magneto" to generate the electrical spark then they could kill an elephant. [/QUOTE]
    That is true to an extent. Commodore coil packs can give a spark upto 110,000 volts, this surge of power is enough to stop your heart for long enough to kill you, same as you don't use a defubulator (what doctors use to re start your heart) when your heart is beating.
    Hangman's Avatar
    Hangman is offline Torana Addict
    2 commys, 3 Toranas and a WB Panel Van
    Jan 2010
    Newcastle, home of Toranafest
    Defibrillators are used when the hearts rhythm is erratic to shock it back to normal rhythm. If the heart is stopped, it's pretty much too late.
    Quote Originally Posted by hakhawk View Post
    there are more pressing issues on the site, like choosing between vl's and potatos.
    Darcon666's Avatar
    The Wife
    Jun 2010
    At home
    You do know you are talking about a DC current in a cars electrical system as compared to AC with far greater Volts/AMPS... there is a difference, anywho lets just stop here.
    Problem is fixed accordiong to the OP, well done /End Thread.
    Dec 2009
    just wondering the coils primary winding recieves a pulse of current, when this current flows into the primary the magnetic field builds up and induces a voltage in the secondary which discharges accross the plug. When the current into the primary stops the magnetic field will collapse/reverse which will reverse the direction of the induced voltage and hence current so won't this make the output of the coil an AC waveform?
    VZ 2005 Executive Wagon
    Sep 2009
    Northern suburbs of Adelaide
    Quote Originally Posted by wortus View Post
    Actually, in an ignition system, it's the other way around. The highest EMF produced in the secondary winding is caused by a collapsing magnetic field, when the current flow in the primary coil is interrupted.
    During my time as an electrical fitter instructor, this was ably demonstrated by getting a 'victim', I mean student, to connect a 1.5 AA cell across a one Henry inductor while holding the leads. No dramas holding the leads while the battery was connected, but when the student disconnected the AA cell, the resulting collapsing magnetic field produced an EMF from hell, and gave them an extremely nasty shock. Very little current, so no damage done, apart from the hands hitting something when flying off with the shock.
  1. washing an ls1 good or bad
    By H1GHROLLR in forum LSx Development and Modification
    Last Post: 26-09-2011, 11:29 AM
  2. [SA] Washing-machine
    By GEORGEZ in forum Parts And Other Items For Sale
    Last Post: 27-11-2009, 05:39 PM
  3. Washing my engine bay
    By Dan366757 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-08-2009, 08:28 PM
  4. washing a ute
    By evil_monkey in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-04-2006, 09:03 PM
  5. car washing
    By gopher in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-10-2005, 07:33 PM
