Results 1 to 6 of 6
Thread: Power Steering Noise
    VN Calais
    Nov 2007
    Default Power Steering Noise
    Replaced a leaking power steering pump & a few days later suddenly have strange noise that appears to be coming from around the rack pinion area. When steering wheel returns to centre from right turn there is a "crack" noise from the rack. No problem when turning the steering wheel to the left. Only requires small movement off centre to cause the noise & only happens with right turn of the steering wheel. Other than noise, power steering functions ok. Rack is reconditioned replacement, 12 months old. Very strange, any suggestions?
    VS l67 statesman
    Dec 2008
    Is it defiantly coming from the rack? or is it the link pins or strut bearings making the noise ? also check all of the rack mounting bolts are tight and the condition of the tie rod ends & ball joints
    VN Calais
    Nov 2007
    Have checked all the suspension & steering joints. Screw driver stethoscope test on rack says it is the noise source. Also no noise when steering wheel rocked with engine off ie no power assist.
    VP Commodore SS 1992
    May 2011
    Auckland NZ
    Also check that your K Frame is tight. There are only 4 bolts. And they are often loose. Its a 1 min job once you have the front jacked up. If they are loose it will feel like a new car once tight again and they also make a clunking noise when they are loose. The K Frame is basically the front cross member it holds the engine and suspension to the chassis.
    Every commodore owner should check this or have it checked.
    VN Calais
    Nov 2007
    Think problem is related to new pump. The 20 year, 400,000k original pump output pressure was probably a bit low compared to that of the new one & this has highlighted an issue with the control valve in the "reconditioned" rack. As it only happens when turning the steering under high load eg stationary or moving very slowly, I will delay servicing the rack until I acquire the bits to do it myself. Stuff paying someone else for another reconditioned rack.
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Your steering assembly has plastic bushes inside it that locate the rack in the housing, they could be broken and may require replacing. (i.e. just get a second hand rack and be done with it)
    The 1972 HQ Kingswood
  1. Power Steering Noise
    By Huthy in forum VY Holden Commodore (2002 - 2004)
    Last Post: 21-06-2010, 06:31 PM
  2. power steering noise?
    By burnsy150 in forum General
    Last Post: 29-01-2008, 11:21 AM
  3. power steering noise???
    By lilkel in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-05-2005, 06:36 PM
  4. power steering noise
    By dungbeetle46 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-04-2005, 09:47 PM
  5. Power Steering Noise
    By vn_calais in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-02-2005, 07:57 PM
