Results 1 to 10 of 10
Thread: t56 5.0 tailshaft ?
    vt s pack manual
    May 2009
    gawler, adelaide
    Default t56 5.0 tailshaft ?
    what tailshaft do i use with a t56 behind a 5.0 ? is it a standard t5 manual tailshaft or custom made ? also where could i buy a hydrolic pedal box set up ? including clutc master cyl n junk.
    dirt drifter's Avatar
    dirt drifter is offline white trash hillbillie
    VS 5L M5 VS 6L M6
    Apr 2009
    massive hole in the ground
    vs series 3 had the getrag gearbox with a hydraulic clutch setup, dunno if that will bolt into your vp though (some say the series 2 vs also was hydraulic, but i own one with a cable-clutch T5)
    mal wood in warwick qld makes hydraulic pedal boxes but they go for damn near $900 i think. he's the man u want to talk to about the swap
    Quote Originally Posted by UFO View Post
    worked v8 + supercharger + dogbox = panty moistening equipment.
    4 banger turbos with bov's will just cry when they hear it, because they can never have it.
    Quote Originally Posted by GRPABT1 View Post
    Avoid cluey police
    VS Stato l67
    Mar 2009
    Melb
    front half of the shaft is different. The rubber coupling that goes from g/box to tailshaft is a different size from VT1 5.0L to VT2 gen3
    vt s pack manual
    May 2009
    gawler, adelaide
    im not paying that for a pedal box,vs will fit. i found out either VL turbo manual or serise 3 vs pedal boxes are the go, ive heard about the suposed serise 2 but i havent seen enough to be convinced. i cant justify mal wood's pricing. going by my own pricing even with a brand new box it only comes to $4800 im not going brand new tho, i will do the conversion for about 3k, just under. and i thought the tail shaft was diffrent, ill just send it off to hardy spicer than.
    VT V8 Calais
    Mar 2007
    Quote Originally Posted by E-T-H-A-N View Post
    Can you elaborate how your doing it for that much? At that price I would be really tempted, have you factored in a diff ratio change with that too?
    50LTRv8
    vt s pack manual
    May 2009
    gawler, adelaide
    i have 3,9s bud, so wont be changing them, in last gear i will sit on 1700 rpm at 100 ks. they cost me 650 to get installed. the box is costing me 1500, brand new clutch was around 400, tailshaft will cost 700 at most, thats everything brand new and custom made. if you use a vt - vz box you will need a custom spigot bush thats about an inch long but you just get it from the hardware store its just copper pipe, if you use a VE box you can get away with just sitting the bush out about 6mm and you wont have a problem there. the pedal box im asuming will cost about 200 at most, custom lines are about 100. comes to $2900. but please note, the pedal box, tailshaft are only rough, i could see them being much less. with the bellhousing you hone it out to suite the started motor, nothing much. if there is anything i have forgotten please let me know.
    VS Senator
    Oct 2009
    vt s pack manual
    May 2009
    gawler, adelaide
    stock t56 but you just hone it out a little for the starter motor to sit in. there the exact same bolt pattern.
    VS Senator
    Oct 2009
    vt s pack manual
    May 2009
    gawler, adelaide
    yeah, sorry i didnt make that specific enough. you use the 5.0 fly wheel and clutch. the input shaft is the same teeth size, the length is shorter tho.
  1. separating tailshaft and tailshaft lengths
    By dans_vz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-03-2008, 08:18 AM
  2. WTB: VN-VS V8 Tailshaft
    By PREDATR in forum Swap / Wanted to Buy / Trade
    Last Post: 08-12-2007, 04:26 PM
  3. VT Tailshaft
    By zeep in forum Parts And Other Items For Sale
    Last Post: 15-08-2006, 06:23 PM
  4. vt-vx tailshaft
    By yeah,yeah in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-07-2006, 09:45 AM
  5. tailshaft...
    By Torquen in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-05-2006, 08:59 PM
