Results 1 to 6 of 6
Thread: Heater wont blow to screen
    Vp Senator
    Jun 2011
    Dandenong , VIC
    Angry Heater wont blow to screen
    hey guys,
    i know its been coverd before but i cant bloody work out or get my heater to blow to screen, its stuck on feet which is probly default,
    vp senator by the way, climate control
    umm would/should be same climate control system as vr/vs would have
    yeah change that little filter box thats located under the head unit, umm tested the butterfly thats located to the left of the headunit just beside the glovebox
    and checked the vaccum hose from the ball, to the manifold through the firwall
    then the one from the heater tap
    still not workin
    TrikkBen's Avatar
    TrikkBen is offline Compulsive.
    BNR32
    Apr 2009
    SE, Vic
    Could be the vac connection from the unit itself. Pop the radio surround out and check.
    Edit: I just saw climate control, my help may not be applicable as I am unfamiliar. Sorry.
    There is no such thing as stupid questions, Only stupid people.
    v6vpute's Avatar
    v6vpute is offline Rolling on stockies
    1993 vp s sedan series 2
    Jun 2009
    Lakes entrance vic
    vn calais 5.0
    Jun 2011
    victoria
    The T peiece breaks in the motor bay near the fire wall.. It's at the back of the motor.. Mine broke and list the vacuum and would not change..
    Vp Senator
    Jun 2011
    Dandenong , VIC
    thanks for all adivce
    see how i go tommorow after work
    just gonne buy big roll of hose and re wire it "outside" see if it works and replace the ones the need it
    let yous know how i go
    Vp Senator
    Jun 2011
    Dandenong , VIC
    worked everything out , thanks for the tips fellas, pumps that heat hard now ahaha
    replaced all fitting to brass and clamped so should last bit longer
  1. heater fan wont turn off???
    By Youngblood in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-03-2010, 01:34 AM
  2. my heater wont work
    By wookie_666 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-05-2009, 07:37 PM
  3. heater issues (wont turn off!)
    By lee.T in forum Electrical Wiring / Questions
    Last Post: 21-07-2008, 08:22 PM
  4. VN heater won't blow in right places
    By timmy_tam in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-12-2006, 11:48 AM
  5. Vp Air Con/heater Wont Work
    By robbie11 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-06-2006, 06:02 PM
Tags for this Thread
