Results 1 to 8 of 8
Thread: Bonnet gas struts
    vn calais 5.0
    Jun 2011
    victoria
    Default Bonnet gas struts
    I'm looking into fitting the gas struts to the bonnet and removing the bar that holds it up.. So my question is will struts from a vr/vs or even newer work and how far from the hinges do I fit them on? Any pics would help as well if you got them..
    vp calais, vn calais, vp berlina all 3.8 litre
    Aug 2008
    Pascoe Vale South, MEL
    i bought a reco'd set off ebay and they do work but there stiff as hell and need a helping hand to spring up. youll also need the mounting knobs that bolt to the top of the guards and the one that screws into the bonnet. its a 10 min job. think the vr vs ones are the same as vp. just go to the wreckers and pocket the 4 bolt knobs and just remember where they go....
    HOLDEN VP-VR-VS BONNET gas struts - new pair !!! | eBay
    dont sweat the petty... pet the sweaty...
    vn calais 5.0
    Jun 2011
    victoria
    Thanks for that.. Will stop at the wreckers tomorrow after work and before I get the kids from school..
    Shortstuff's Avatar
    Shortstuff is offline Random
    1995 VR II V6 Wagon
    May 2006
    I did a how to on it ages ago. It's still here somewhere. VR or VS struts will fit. You just need a nut that will fit on each of the studs that come out of the bonnet as there are no threaded holes on VN bonnets.
    Here's the link to the how to.
    Fitting Gas bonnet lifters to a VN
    Whoever said 'There is no substitute for cubes' had obviously never heard of Jet power
    vn calais 5.0
    Jun 2011
    victoria
    vn calais 5.0
    Jun 2011
    victoria
    Was looking at the bolts on the guards and then looked at the bonnet and it has the holes on the side.. Spoze I don't have to drill holes so I'm half way there
    Aug 2008
    Quote Originally Posted by Shortstuff View Post
    didnt realize that cause when i did my vn it changed it to a vp bonnet, the other one was stuffed and i was doing a respray anyway... that nut on the wire is pretty clever nice one....
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Also make sure you get some flat-top studs for the quarter panel. The standard nuts won't give the struts enough clearance when the bonnet shuts.
    They have studs on them, and you do the nut up from underneath. They're the white squares in this picture:
    The 1972 HQ Kingswood
  1. Bonnet struts
    By bacon in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-06-2010, 11:26 AM
  2. Bonnet Struts
    By markER717 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-08-2009, 04:17 PM
  3. bonnet gas struts
    By VL Berlina 5speed in forum General
    Last Post: 28-12-2008, 10:16 AM
  4. [SA] WTB: Gas Struts for Bonnet VN
    By 2001_VXSS in forum Swap / Wanted to Buy / Trade
    Last Post: 16-12-2008, 07:21 PM
  5. Bonnet struts
    By killuminati in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 04-10-2005, 04:15 AM
