Hey guys I need your help again. My '91 VP's instrument cluster dash lights, T bar and heater lights don't work. the instruments and parklight do work. The fuses aren't blown and the globes are ok. Any ideas on what could be causing this?? any ideas, help or suggestions would be very much appreciated.
Vicci.
Not sure if VP's are the same as my VN but in mine the power is all fed from the light switch on the binacle and go through the fuse to the TBar etc, and go direct from the switch for the tail and cleaarance lamps.
The fuse and globes may be OK but have you checked there is power either side of the fuse, maybe theres a problem with the block/connections where the loom goes onto the switch binacle and feeds the fuse?
my lights on the tbar does not work too.. have changed the globes and still no lights and the cigy lighter does not work as well..
