Results 1 to 7 of 7
Thread: Vp rear l/h side door trim
    1966 HR Holden, 1992 VP Commodore
    Jan 2011
    Gold Coast
    Default Vp rear l/h side door trim
    Hey fellas,
    My L/H rear door doesnt lock with my central locking? want to take off the door trim to have a gander, any tips would be great?
    commodore
    Aug 2009
    australia
    its probably the actuator solenoid thing thats stuffed or a bad/loose wire in the door.
    VN Excecutive
    May 2011
    South Australia
    When you get the trim off, have a look at the little yellow plastic piece that turns when the central looking is activated, with mine the yellow piece was broken. Witch means the motor pushing it is doing nothing. A small cable tie around the motors "ram" (for lack of a better word) onto the yellow plastic thingo and PRESTO! central locking fixed! that is if its the same problem I had HAHA.
    When you get the trim off it will all make sense.
    Good Luck
    Jan 2011
    Gold Coast
    okay cheers
    and tips on taking the door trim off, i knows theres 2 screw, and clips all arounnd the door (broke several already) just with getting the window winder handle off, and getting the lock button out of the road?
    Morton's Avatar
    Fairstar the Funship
    May 2006
    The winder is held on by a c-clip. Try and prise it away a little, and look behind it with a torch. Find the back of the clip, and push it away and out.
    It'll go flying - catch it.
    The orange tab on the door lock button can be removed with a small screwdriver on the side, levering out. Prepare to break it if you havn't done many before.
    The 1972 HQ Kingswood
    VN Excecutive
    May 2011
    South Australia
    I found the best way to get the C-clip out is to get your shirt between the winder and the door, then move (your shirt) left to right while pulling down. Like Morton said it will ping off quickly.
    VKCOMMO's Avatar
    VKCOMMO is offline Carpark Mechanic.....
    Aug 2009
    Springwood, NSW
    Yeah, Just get a rag behind it and pull up until it pops...
    [09-01, 22:47] HoZy: VKC doesnt finger, He fists... Because Ranga
  1. VT rear door trim
    By hammasteen in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-05-2010, 04:02 PM
  2. Rear door trim.
    By Humm in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-09-2008, 10:06 AM
  3. VY/VZ Passenger Side Rear Door Trim
    By Marzz in forum Swap / Wanted to Buy / Trade
    Last Post: 26-02-2007, 08:29 PM
  4. Rear door trim for wagon - sedan the same??
    By mad13b in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-01-2007, 08:58 PM
  5. how do i remove rear right door trim?
    By gocommygo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-05-2006, 09:16 AM
