Page 1 of 2 12 LastLast
Results 1 to 25 of 27
Like Tree1Likes
Thread: vp headlight upgrades
    vp
    Oct 2010
    sunbury
    Default vp headlight upgrades
    so the missus vp lights r shit. what are people doing to upgrade them? dont want hid. would new lenses and new globes do it? what globes are peeps using?
    VP Berlina
    Jun 2011
    Epping, Sydney
    I'm sure you could give them a nice polish up; make them crystal clear, with some brilliant white Halogen bulbs? I made the change on my previous car. The 5000K white lights up the road alot more than the previous standard incandescents.
    vp
    Oct 2010
    sunbury
    cheers mate, thats what i was going to try. probly the cheapest option first up i guess
    VP Berlina
    Jun 2011
    Epping, Sydney
    Exactly. Process of elimination cheapest to most expensive is always best.
    You'll find if you can get that lens as clear as glass, the new 5000k brilliant white bulb will light up the way like nothing else. Just make sure it's brilliant white.
    Though, i'd like to know.. Is there any way to pry off the lens, from the actual headlight unit, so as to polish the inside without damaging seals? I don't need to now, as the headlights are clean as a whistle; though.. It's always good to have that little bit of extra knowledge in the squishy thing in my head.
    Thankyou, and good luck!
    vp
    Oct 2010
    sunbury
    vn calais 5.0
    Jun 2011
    victoria
    Just undo the lights and indicators and take them out then pop the 10 clips off and it just comes apart easy.. Did mine a few weeks ago and cleaned them on the inside glass.. Didn't touch the silver light reflector..
    vx gen111 wagon
    Jul 2009
    perth
    yep easy remove the 10 clips and remove lens BUT DO NOT TOUCH THE SILVER SURFACE it will be very weak and dirty but if you try and clean it you end up wiping the silver off
    VP Berlina
    Jun 2011
    Epping, Sydney
    Beautiful. Thanks guys. I'll get in there and clean them out when I change my globes to Brilliant White!
    calais_cruzin's Avatar
    calais_cruzin is offline Calais_Rattling....
    92 VP Calais 3.8
    May 2006
    Gold Coast
    Its most likely its the reflector as too why there not as bright as they should be
    After a good decade the shine fades away making it reflect less light.
    Id pull em apart, try clean any residual dirt off the reflector and glass and see if any gain have been had.
    Im about to replace my lights, reflector has patches of dull browny silver and can barly see the road in the rain.
    Ebay has em cheap 80-100 for pair, cant complain with that price
    ________________________________________
    vn ss
    Feb 2010
    yeh but the ebay lights are non gen and are crap..... my car came back from panel beaters with non gen lights in it and they worked crap so i went to wreckers bought sum old gen pair of lights took em apart like you said cleaned up and walllllllla!!! good as gold with sum decent globes
    VQ Caprice II
    Aug 2006
    Hiya,
    VN,VQ, VP, all this series the lights only work well if there is good reflection of light through the glass lens.
    Your best bet would be to chase a good set of reflectors, all vn/vq/vp have the same part here, but the headlight glass is unique to vp as it curves more, but get ones with the reflector strip intact.....as in most cases without the reflector strip on the bottom edge of the glass, the light will bounce into the bumper/body space instead of bouncing out to the road. Another option is you can get some high temp engine spray in sliver and spray the bottom edge of the glass and that will help reflect the light onto the road.
    thanks,
    Verynice's Avatar
    Verynice is offline Band
    VS Caprice 5L
    Aug 2008
    SA - The Backwards State
    Who says 5000k light up the road better??? they illuminate worse. Chuck a set of philips extreme vision globes in and polish up the covers.
    VP Executive 5L
    Mar 2011
    Holdens of this era seem to have a gutload of scungy thin wires. I'd add a pair of relays next to each headlight with nice fat wire (and a fuse!!) from the battery, and use the original globe feeds to run the relays.
    vn calais 5.0
    Jun 2011
    victoria
    My reflector tape stuff on the bottom of the glass is gone and the previous owner painted the bottom if the glass black.. I put 90/100 globes in it and it's not too bad after I cleaned the glass on the inside.. What can I use to replace the silver on the bottom of the glass?
  15. #15
    TVR-190's Avatar
    TVR-190 is offline SkyFall
    WK Statesman LS1
    Jun 2008
    Sutherland Shire N.S.W
  16. #16
    VQ Caprice II
    Aug 2006
    Quote Originally Posted by mr calais 5.0 View Post
    as stated above, you can re-paint the glass with some engine hi-temp enamel in sliver, or if you can get your hands on some spray on glue that is heat resistant to the heat the headlight produces, you can try to stick some reflective alluminium foil to the outside bottom edge of headlamp, for me the heat paint, worked fantastic.
  17. #17
    vp calais, vn calais, vp berlina all 3.8 litre
    Aug 2008
    Pascoe Vale South, MEL
    if yours are pitted and ugly after market ones are available for 50 bucks a pop. im going that way on my project car... just a thought...
    dont sweat the petty... pet the sweaty...
  18. #18
    vn calais 5.0
    Jun 2011
    victoria
    cool might give the silver paint ago or if i can finda some good glass lights at the wreckers..
  19. #19
    wraith's Avatar
    wraith is offline Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    Hope you have the wiring ready to replace when it melts. Not a matter of if but when.
  20. #20
    vn calais 5.0
    Jun 2011
    victoria
    had the same globes in my 1990 pajero for 3 years and never melted a wire or had a prob.. The previous owner had 100/130 in the lights so i took them out
  21. #21
    wraith's Avatar
    '95 VR Series II
    Sep 2008
    Demonicaland
    Would you like a picture of the last car I have seen with the same globes. Nice and crispy wiring.
  22. #22
    vn calais 5.0
    Jun 2011
    victoria
  23. #23
    92 VP Calais 3.8
    May 2006
    Gold Coast
    if u upgraded the wires from relay to headlight with thicker guage wire there wouldnt b a prob mr calais
  24. #24
    vn calais 5.0
    Jun 2011
    victoria
    I have a few mates that have done the head light loom upgrade and it works well when your running bright globes.. I don't have a prob with the wires or plugs in my car I'm just missing the silver tin foil stuff off the bottom of the glass..
  25. #25
    VN Series 2, FG R6 Ute
    Aug 2007
    S/E Suburbs
    I'm a little confused with the relay idea. It sounds good, because the passenger side light in my VN always needs to be replaced quite regularly.
    Using a relay, how would you do it? I'm normally pretty good with these things, but I haven't looked at the wiring for a long time on the VN. Is there 3 wires? Brown, Black and Green???
    Have I got this right?
    Some more info of the wiring up of the relay would be good.
    Thanks,
    Stockies.
  1. vl upgrades
    By INtensity in forum VL Holden Commodore (1986 - 1988)
    Last Post: 14-09-2010, 10:26 PM
  2. upgrades
    By blu_ute in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-09-2008, 09:02 PM
  3. what upgrades should i do??
    By jester 21 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 02-08-2008, 09:12 AM
  4. v8 upgrades
    By matt69 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-10-2005, 10:00 PM
  5. Car upgrades?
    By kurtbarker in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 01-06-2005, 09:51 PM
