Results 1 to 14 of 14
Thread: vp ss project
    vp ss
    May 2011
    cairns
    Default vp ss project
    anyone got any idea on cheap mods for my vp ss 308 fuel injected
    vn calais 5.0
    Jun 2011
    victoria
    How cheap and what do you have in mind doing? Just give us a bit of an idea..
    Jul 2008
    The cheapest would be to sell it to me.
    Budget ? 1g or less, Forget it, sell the car. (
    Apart from some cheap spring/shock combo and a drony cat back exhaust. To do either of these things properly will cost close to a grand. A good suspension package around 900, A good exhaust is close to 800 aswell.
    1g or more, There is PLENTY you could do, but nothing nasty and cheap.
    vn calais 5.0
    Jun 2011
    victoria
    do you want more power or looks or wheels? A pic of the beast would be sweet
    vp ss
    May 2011
    cairns
    i want power not looks at the moment and what i meant buy cheap was around 1500
    Jul 2008
    VP SS, Cammed VN V6 daily
    Jan 2010
    a 2nd hand cam for 1500!! you can get a new cam installed for $1500 or DIY and get some exhaust work too
    vp ss
    May 2011
    cairns
    vp ss
    May 2011
    cairns
    Verynice's Avatar
    Verynice is offline Band
    VS Caprice 5L
    Aug 2008
    SA - The Backwards State
    Quote Originally Posted by nathan01 View Post
    is it hard to install a cam
    if you have to ask that question, then yes it is.
    vp ss
    May 2011
    cairns
    worked on head and stuff not on cams or piston so i should get it installed
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    Quote Originally Posted by DavoVP View Post
    Fail right there. There is a **lot** you can do to those old things to get them moving for less than $300.
    1. Good service - plugs, rotor button, cap, leads and also a new coil. (it's probably seen better days about 10+ years ago) Also check timing - set it to 10deg BTDC (important for later)
    2. Corvette servo if it's an auto
    3. CAI (not a lot of gain there but it does help a little bit)
    4. 2.5" cat back system (I put a redback one on and it did an excellent job for $180)
    5. Replace the cat if it's blocked
    6. Tune.
    7. Spool if you want a track car - for the street they are a pain in the rear
    That is enough to get you down to very low 14's or maybe even knocking on the door at 13 sec 1/4 mile with good tyres/track. It'll never keep up with the newer ls based cars but for a cheap car it's excellent value for money.
    From there they sky is the limit cost wise but it's a great and very noticeable start. Check out the VP thread in my sig for a (very) long version of the above.
    Unless your cam is stuffed (then only get a super mild one), it's a waste of money unless you do a whole engine build with more compression, cam, manifold, tb and so on but that starts getting expensive.
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Reaper you forgot diff gears. Theyre excellant for a cheap yet effective performance they wont give your more power but increase in acceleration makes a huge difference especially on street
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    vp ss
    May 2011
    cairns
    cool thanks yeah was just looking at your vp looks mad i want mine white though
  1. Replies: 27
    Last Post: 21-06-2011, 08:31 PM
  2. VH SL Project
    By ignitionvess in forum VB - VC - VH - VK
    Last Post: 07-02-2010, 02:51 PM
  3. My new old car project. VK
    By Gthofan in forum VB - VC - VH - VK
    Last Post: 21-01-2010, 07:58 PM
  4. YAP (yet another project)
    By hakhawk in forum Miscellaneous
    Last Post: 20-06-2009, 03:42 PM
  5. My project VL car
    By Paiste402 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 01-04-2008, 06:56 PM
