Results 1 to 6 of 6
Thread: Transmission Fluid
    '88 VN Sedan
    Jun 2011
    Default Transmission Fluid
    I want to service the auto in my Series 1 VN & the owners manual says to use Dexron 11d ATF. I'm struggling to find a suitable replacement due to unclear labels that talk about every Dexron grade except Dexron 11 or 11d. As near as I can tell Castrol Transmax M is what I'm after but I want to be sure before I actually start the service. The last thing I want to do is pour the wrong stuff in there & fry the trans. Can anyone offer any advice?
    Thank you.
    '88 VN Sedan, stock V6.
    69 rs ss camaro/ rodeo dual cab
    Jul 2011
    adelaide
    Default hipee trans fluid
    Mate u can use dextron 3 ive been using it in my vp senator for years, after i got my trans fully re built mechanic advised that it was ok to use
    '88 VN Sedan
    Jun 2011
    Thanks Hipee.
    Looks like I'm actually going to have to go spend some money then. I was hoping the Transmax M would be ok as I have heaps of that already & I wouldn't have to buy new ATF.
    mischa's Avatar
    mischa is offline <- 245rwkw Holden V8
    VN V6 T5 - 355 VN GRP A REP T56
    Jun 2005
    Ashbury, NSW
    Transmax M should be ok for it, ive used it before.
    Quote Originally Posted by keza87 View Post
    Really who wouldn't want to give Jack a good smack in the back of the head.
    The Daily VN T5V6
    355 VN GRP A REP
    Dec 2009
    Castrol Transmax M used to be their Dexron 2 so it's probably OK as long as it's spec GM6137M is what a VN needs, Dexron 3 would be better if you drive it hard or tow etc.
    '88 VN Sedan
    Jun 2011
    Thanks for the replies. I ended up I just bought some Castrol TQ-DIII & used that. It's not like it costs much so I decided to go with something that offers a bit more than the Transmax M.
  1. transmission fluid
    By GMHCalais in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-03-2011, 02:31 PM
  2. How much transmission fluid?
    By deXtrous in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-09-2010, 10:28 PM
  3. Which transmission fluid
    By jonathanvb in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-02-2007, 06:50 PM
  4. Transmission Fluid
    By Indy_387 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-06-2005, 01:03 PM
  5. Transmission Fluid
    By MavVP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-08-2004, 10:07 PM
