Results 1 to 24 of 24
Like Tree2Likes
  • 1 Post By Brett_jjj
  • 1 Post By VK SL 3800
Thread: Fuel Dampener installed amazing improvement V8
    VP Commodore SS 1992
    May 2011
    Auckland NZ
    Default Fuel Dampener installed amazing improvement V8
    I always wondered why my SS felt so rough. Ive had a 97 HSV Senator and the same engine felt so much smoother.
    Anyway I noticed my SS didnt have a dampener fitted, so today I went to the wreckers and got a dampener from a 3.8L VR, unbolted the mounting tab and installed it near the fuel rail entry just like my HSV had and viola my SS runs smooth similar to my HSV.
    Anyway I suspect these little devices improve the fuel delivery by evening out the fuel pressure and they make a big difference to how the car runs. So if anyone elses V8 is running a bit rough I would recomend chucking one on, it only takes 10mins and stinging eyes.
    Ps definiatly depressurise your fuel system (there is still pressure after) so, WEAR SAFTEY GLASSES TOO !
    I might try installing 2 ? Thoughts anyone
    db_notso's Avatar
    db_notso is offline diagnostic technician...
    vt v6, mods(susp brakesetc...)
    Oct 2010
    sunshine coast, qld
    fuel dampners are normally fitted to cars with big pressure loss when the injectors are firing....
    as it "dampens" the loss of pressure by sort of temporarily increasing fuel pressure as it drops to maintain a smoother fuel rail pressure,
    its basically like a spring loaded valve that is designed to oscillate with fuel rail pressure fluctuation
    basically it oscillates in time with injector pulses, fitting two will make one dampen the other and likely give little change to the rail pressure consistency.... but yeah they were goin to fit a dampner incorporated to the fuel pump on return but decided was too expensive in mass production as not EVERY car showed signs of fuel rail pressure fluctuation...... for whatever reason....
    May 2011
    Auckland NZ
    My car must of had significant fuel pressure fluctuation ! It runs so much nicer now. Smoother idle and smoother power delivery I would even say quicker. I was thinking of just having the two dampeners in line but maybe even splitting the fuel line and running them parallel.
    When I used to squeeze my fuel inlet line i could feel the pulses they were the same pulses that ran through my car and probably even pulsed into my engine making it run rough. Now when I squeeze the hose after my Dampner it feels smooth like there are no real significant pulses.
    So GM were going to fit one on the return line ? Near the fuel tank ?
    If you were going to fit 2 where would you put the 2nd one? Also why do you think my SS didnt have one at all ?
    Sorry for all the Qs, I have a few avaliable at the moment for free so Im going to try it out. Even if I get 10% of the improvement I got with fitting one it would be worth it !!!
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    I always was told they dampn pulses from the fuel pump not anything to do with injectors
    If they were to have anything to do with injectors wouldnt make sense to fit them after the injectors not before?
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    May 2011
    Auckland NZ
    I think they have more to do with the injectors than what yourve been advised. Think about this, the injectors use the pressure in the rail to inject the fuel, if the fuel pressure is fluctuating the injectors pulse will be inconsistant. The dampner smoothes out the fuel pressure by storing pressure and releasing in evenly thus the injector sees consistant pressure.
    Im sure there is a better way of describing this.
    My car didnt have one so I put one on today and its made a HUGE difference. Now Im thinking if one makes a big difference can 2 make a bit more of an improvement.
    vs commodore
    Oct 2009
    Tamworth NSW
    Quote Originally Posted by Pub247 View Post
    Ive heard the same,that they smooth out, or dampen out peak fuel pump pressures..
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Quote Originally Posted by 92 VP SS View Post
    Umm isnt that what a fuel regulator does stores up pressure in the rail so fuel pressure doesnt fluctuate
    May 2011
    Auckland NZ
    From what I've learnt in trying to find out why my car runs so much better with a dampner installed, is the regulator is a relief valve for the overall pressure of the system and the dampner levels out the pressure spikes caused by the pump and the pulses of the injectors.
    Im certain the dampner has an affect on the consistancy of the pressure the injectors use. My theory is the more consistent pressure in the fuel rail = more consistent injection of fuel.
    Pub247 does your VP have one installed ?
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    yes my vp does my old vk efi had 2 aswell one near the pump and another before the rail
    calais24/7's Avatar
    calais24/7 is offline Mucca Mad Boys
    VS Calais II 5L, 98 rodeo v6
    Jul 2009
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    I might just add, When i converted my car to a v6, the V6 has one behind the throttle body, and the VK EFI pump had one just off the pump, i have since fitted a VS tank and pump without the second dampener and i haven't noticed any difference.
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Quote Originally Posted by calais24/7 View Post
    Can you show me what they look like and where they go lol?
    I googled for a pic for you and found a thread i posted lol, so heres a VK EFI pump and regulator:
    EFi Pump Question
    May 2011
    Auckland NZ
    I definiatly think you need at least one, preferably at the inlet to the fuel rail. But Im going to see if I get an improvement by adding another one.
    Pub247 or VK SL 3800
    Was the one near your fuel pump after the fuel filter near the tank ? I think my VP SS has 2 pumps, I know one is in the tank but I dont know where the 2nd one is, I think putting one after the 2nd pump may further improve my injection system.
    Calais 24/7 the fuel dampner should be on the inlet side of the fuel rail opposite side to the regulator, it looks like a round UFO on the passenger side of the car.
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    On a VK EFI its before the Fuel filter straight on the outlet of the pump, fuel system in the earlier girls goes something like this:
    Pickup into pump, through dampener 1, through filter , through dampener 2, into fuel rail: Out injectors or through the regulator -return to tank.
    My understanding is its main purpose is to stop line shudder or chatter from any sudden fluctuation in line pressure, basically its like one of those thing you buy to stop your pipes rattling in your house when you shut of a tap quickly, except the injector is the tap and your pump is mains pressure.
    Older 'batch fire' injection is more subject to it as all injectors fire at once creating a more sudden buildup of pressure once the injectors close, it can create a sudden spike in pressure as the pump is ramming all the fuel up the lines and then the regulator hasnt opened quickly enough to allow pressure to escape.
  15. #15
    May 2011
    Auckland NZ
    Ok great thanks VK SL 3800. I will try running two on my SS to see if I get any further improvements when it didnt have one near the rail it was awful in hindsight but I put up with it because I love my old beast.
    I assume 1 dampener is critical and the 2nd probably wont have a great affect but I will find out either way when I find where my 2nd fuel pump is located ! Will hit the forums unless anyone readily knows where the VP 5L fuel pumps are located ?
  16. #16
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    If its got two it will be up and under the back just follow you fuel lines from the tank, but i thought VP's went to a single pump arrangement.
  17. #17
    May 2011
    Auckland NZ
    Yeah I think your right mate, just did a thorough search through the forums and it seems the dual pump setup finished with the VNs, and the VPs have a single high pressure pump in the tank. Well Im going to pop a dampener on there just like you VK had originally.
    I think I read somewhere there is a dampener on the pump in the tank but I would say that mine was either faulty or ineffective and with the results I got from putting a dampener before the rail I will be happy if i get a further improvement :-)
    Thanks for you help/info. I will post back when Ive put the 2nd one on and let the forum know of any further improvement. But I would strongly recomend at this stage if one is not fitted at the fuel rail to get one on I just used one from a VS 3.8 and have another the same that will go after the pump near the tank.
  18. #18
    VP Executive 5L
    Mar 2011
    Quote Originally Posted by VK SL 3800 View Post
    Yeah, I was going to say that too.
  19. #19
    vn calais 5.0
    Jun 2011
    victoria
  20. #20
    May 2011
    Auckland NZ
  21. #21
    db_notso's Avatar
    Oct 2010
    sunshine coast, qld
    just looked into this a bit more today embarrising yes
    its normally before in side of fuel rail from the pump
    and SOME higher pressure systems (mercades and other older models holden etc)
    had a dampner EITHER incorporated into the fuel preasure reg.or part of the fuel pump assl'y
    there is one i have in the yard at work (old 5 litre??? or it was once )with 2 dampners with v6 stamped on them in parrelel on a v8..... not going to have time to play with it for you nor do i know what they are off....
    and the pumps pulsating issues i found came down to three things
    pump worn vanes......(pump dead)
    fuel FLOW too low (pressure ok at idle but)......(pump dead)
    or injectors too big for supply from pump/fuel rail.......(bigger fuel rail)
    this is not my forte here obviously..... but from what i can gather if fitting a fuel dampner makes it idle smoother
    you may have a fuel pump issue OR the engine is modified and the fuel system cant keep up (normally this would be from strokers)
  22. #22
    vr8-mafless, thats right mafless
    Feb 2012
    nsw
    the damper on a vr and vs v8 (not sure about vn or vp but suspect the same) is fitted above the left bank cylinder head on the fuel supply line. It is just a can (bosch part) much like a mini sized swirl pot. You can blow straight through it from one pipe fitting and out the other.
  23. #23
    VP calais, VJ valiant, BG5 legacy
    Jan 2008
    New Plymouth, New Zealand
    I dont think fitting a second one is going to give you any great imporovement, basically it works a bit like a capacitor for fuel - it just evens out high and low pressure pulses. Unless these pulses are actually exceeding the capacity of the first one a second one isnt going to make any difference
    Quote Originally Posted by QuickVRII95 View Post
    Elaborate, For All Of Us... How The Hell Is A Commodore A Friggin 4-Stroke...???
    Where Are You Getting Your Facts From...???
    You All ARE Wrong About A Commodore Being A 4 Stroke Engine... Or Any Car For A Matter Of Fact...
    A V6 CAN'T Run On ONLY 1 Cylinder... IT'S A 24 STROKE ENGINE... 4 CYCLES Per Cylinder... "Basically Three V-Twins Together
  24. #24
    CALAIS94 is offline Banned
    calais
    Feb 2012
    australia
    pictures of said dampener
  1. VN s1 valve springs: dampener or double?
    By savage1987 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-04-2009, 09:53 PM
  2. Starting issues after new fuel filter and injectors installed!! HELP!!
    By SKNOT9 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-06-2008, 06:17 PM
  3. Remove Fuel Dampener?
    By Dan355 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-10-2007, 08:14 PM
  4. Sound Dampener
    By garfa in forum Car Audio
    Last Post: 13-08-2005, 11:23 AM
  5. Cosmetic improvement
    By Gerry Murphy in forum General
    Last Post: 19-05-2005, 10:37 PM
