Results 1 to 11 of 11
Thread: odometre stop start stop start???
    69 rs ss camaro/ rodeo dual cab
    Jul 2011
    adelaide
    Default odometre stop start stop start???
    Any one know why odometres work one minute stop the next ive got a vp 4.9l auto and its p€€sing me off. Any ideas guys
    vn calais 5.0
    Jun 2011
    victoria
    Does the speedo still work? Mine both stopped and it was the speedo sensor on the back of the auto..
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    if ya speedo is still working..it means the cog that runs the odo has broken teeth on it, or is about to break
    very easy and cheap to fix,..
    All you gotta do is, take the cluster out, open it up..and remove the odo cog,.. a new cog on ebay is like $10.. or go to the wreckers and get one, I will find you a How to guide, it's got pics to help aswell
    Paintball.. It's not just a Sport.. It's a lifestyle!
    Check out my VS Wagon !
    See my Re-Mixes here YouTube - Dtek5
    vn calais 5.0
    Jun 2011
    victoria
    Jul 2011
    adelaide
    Default odometre
    Cheers speedo still works so i guess its th cog on its way out, isnt takin the dash cluster out a bit of a pain, if im goin to do that i might replace black facia with a red one itll look better seeing as car is red. Cheers
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    Its actually very easy,.. There are two screws that face up on your cluster, undo them.. then the buttons on the right and left will come off with the shroud .. undo the clips, then pull the cluster out, VERY easy.
    Then undo the cluster itself, there are screws , and its very easy to do
    But if you're going to change the fascia over, then id recommenced wait till you have it
    VP exec ser2 wagon
    Aug 2005
    Sorry for hijacking your thread but I have a similar problem. odo stopped working and speedo is intermittent. Would the one cog effect both or are there 2 cogs I need to replace? Thanks.
    VY SS
    May 2011
    Auckland
    Sorry to highjack too. My vs odo always worked but on cold mornings the speedo didn't for the first half hour of driving. Only ever did it in winter and odo still ticked over
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    Quote Originally Posted by stockhorse View Post
    From my experience, it was just the one cog that would affect.
    If you're speedo is intermittent, I'd be checking you're Speed Sensors, chances are it's ready to die.
    it's at the back end of transmission i think on the drivers side
    Quote Originally Posted by m1lky View Post
    Chances are you have a sticky speedo.. Normally, just bang the top of the cluster to work, but.. The reason why its doing that is, a solder connection in the Cluster is in poor condition, and will cause this.. It's very easy to fix, just resolder the connection I can find a pic if you need.
    It's very common problem in Vn's to Vs's. . VT onwards, Im not sure tho.
    VY SS
    May 2011
    Auckland
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    Already sold. Just curious
    Hahaha, good man
    But, at least you know and can pass the info to you're buddies if they need help...
  1. vt start then stop / immobiliser issue? dead key? PLEASE HELP
    By jamie123 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-06-2011, 12:02 PM
  2. vs calais wont start unless i kit unlock before i start
    By scottmcguinness172 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-05-2011, 06:40 PM
  3. Overheating in stop start traffic only - VZ SV6
    By MissSV6 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 16-11-2010, 04:00 PM
  4. knocking noise when i start my car and wont stop i need help
    By red goes faster in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-12-2009, 01:12 PM
