My car keeps flooding itself when you turn it over, it has spark and ia getting fuel but will not start, ive replaced spark plugs in it because the other ones were getting to wet with fuel. Any ideas? Cheers
If its to loud your to old
When the car finally kicks in.. Does it blast smoke out the the exhaust that smells like strong fuel?
If yes, then it's most likely you're Fuel Regulator is shitting out, when it fails It will flood the engine.. Learned from my old VP haha...![]()
Won't kick at all, hmm sounds convincing to me ill have a play with it thanks mate
If all else checks OK and no fault codes for engine management sensors etc, then how's the injectors not worn and leaking fuel possibly?
