Results 1 to 2 of 2
Thread: re occuring ignitian fault. Please help
    VN calais v6
    May 2009
    Default re occuring ignitian fault. Please help
    Hi again
    I had a problem with my vn v6. it would start then stall and not start again. I was told that it was either the fuel pump or the coil packs. I replaced the fuel pump because I couldn't hear it running.
    I did the diagnostic and got error code 41.
    I replaced the crank angle sensor and the car was fine for a week then started doing it again.
    error code 42. I replaced the coil pack, leads and plugs. reset the computer and away it went with no error codes. I did not replace the ignition module though as I couldn't afford it.
    it lasted for 2 weeks now I am back to error code 41 crank angle sensor. I haven't used second hand parts, only new. what should I look at now?
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    Possible that the o2 sensor is dying, it can cause it to stall when you've started it.
    When it does start, and is about to die.. Do you rev it? if so... does it still stall.. or only delay it, then it will stall again?
    Another good lil trick I was told, prime you're fuel pump twice.. so turn the key all the way to the point, just before it will fire the engine.. and do it again, 3rd time fire the engine up and see what happens.. if it fires up 1st go, normally it's fuel pressure thats low, and MIGHT cause the CAS to show an error.. my ol' vp did that too =( ...
    Paintball.. It's not just a Sport.. It's a lifestyle!
    Check out my VS Wagon !
    See my Re-Mixes here YouTube - Dtek5
  1. Engine fault light comes on and stays on but fault code says no fault?
    By hildahoop in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-06-2011, 05:46 PM
  2. ABS Fault
    By orthaeeoul in forum VY Holden Commodore (2002 - 2004)
    Last Post: 04-11-2009, 09:46 AM
  3. SRS Fault, help please
    By Jakhama_2_mcmetz in forum VY Holden Commodore (2002 - 2004)
    Last Post: 13-02-2009, 11:18 PM
  4. Is this VP fault, V6 fault or just bad luck?
    By MyVPIsFasterThanYourVP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-12-2006, 10:46 PM
  5. Fault light came on but reports no fault
    By VRBerlina05 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-08-2005, 07:21 PM
