Results 1 to 12 of 12
Thread: vn calais rear door window switches
    1990 VN CALAIS 3.8 LITRE V6
    Jul 2011
    shepparton
    Cool vn calais rear door window switches
    hi all
    I got a qurestion bout my rear door window switches in which case are not working but the rear switches on the master panel work but the rear ones on the doors dont work.
    i have pressed the childlock switch numerours times but that doesnt seem to do anithing maybe its broken i dunno?
    ani thoughts/ideas would be really hepfull
    D22 St-r Navara
    Dec 2010
    perth
    you could try resoldering the connections on the switches. might have dried out if that doesnt work get other ones
    Jul 2011
    shepparton
    D22 St-r Navara
    Dec 2010
    perth
    Jul 2011
    shepparton
    my power window module fine all the switch es in the front work but the switches on the back doors do not move the windows maybe its the childlock is stuck on or sumfing????
    Jul 2011
    shepparton
    Munz's Avatar
    Munz is offline Right Foot Action
    VZ Calais LS1 / VL RB30e daily
    Jan 2011
    Brisbane NTH
    Munz's Avatar
    Jan 2011
    Brisbane NTH
    Vn Vacationer
    Jan 2007
    Check pin 1 on the rear switches to see if power is there. If not both switches are fed from the same point on the front switches, maybe as you say its the child lock button.
    Jul 2011
    shepparton
    yeah both rear door switches dont light up and have tested the pins and get no power so must be the childlock ??? if so how would i go about fixing/ditching/bypassing the childlock
    ani ideas much appreciated
    its driving me nuts
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    Quote Originally Posted by JuZo!!! View Post
    its driving me nuts
    When you remove the drivers side master switch you will see a red wire going to the pin for the child lock underneath. In order to bypass you need to bridge a wire from the red/yellow > red wire. That will fix it
    Power is measured in DECIBEL
    Jul 2011
    shepparton
    thanks a billion SWEETWAGON it worked my back door window switches are working now thanks m8
    I happy now
    cheers :P
  1. any1 know how to change the power window cable on vs calais rear door?
    By cxcxcxvcvcvc in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-09-2009, 08:38 AM
  2. [SA] WTB: VN-VS Pair Of Rear Door Power Window Switches
    By PREDATR in forum Swap / Wanted to Buy / Trade
    Last Post: 11-01-2009, 08:50 PM
  3. feeler: calais spats, electric mirrors, window switches, chrome door strips
    By hakhawk in forum Parts And Other Items For Sale
    Last Post: 01-10-2008, 11:45 PM
  4. VL Calais Rear Window Switches Elec
    By VQUARTER in forum Electrical Wiring / Questions
    Last Post: 22-01-2007, 08:47 AM
  5. VK Calais Rear Window Switches
    By SpeedDemon in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 14-07-2005, 10:14 PM
