Results 1 to 6 of 6
Thread: VN help please
    JGlinatsis is offline Ratty
    Vr Executive 3.8 V6
    Apr 2009
    Default VN help please
    Hello how is everyone?
    I just got a clapper VN lexen and I have my full exhaust from my 93 VR extractors Y pipe and cat back will that all bolt up to the VN and if so what is the best way to get it off with out taking the motor out? I was thinking unbolt the engine mount's and jack it up from the sump with a plank of wood or something so i don't push it in.
    '88 VN Sedan
    Jun 2011
    Couldn't tell you if the extractors will bolt straight up but I can tell you not to jack the engine up from under the sump, plank or not. Better off using an engine hoist or block & tackle to lift the engine if you need to.
    '88 VN Sedan, stock V6.
    matty94's Avatar
    matty94 is offline Addicted 2 VN's
    Vn Berlina
    Apr 2011
    Dandenong area S.E VIC
    Yes it will all fit but i don't see why you need to take the engine out to fit the extractors and never jack your motor up from the sump.
    VN White Berlina Sedan V6 (S1) Full Lukey Exhaust Lovells Springs 15x7 Interceptors v8 Throttle Body Custom Tune Calais Grill Mulberry Calais Seats 2 12Inch Alpine S-Type Subs Level 3 Cluster.
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    I believe the hangers on the exhaust are in a slightly different spot from vr to vn, exhaust shop can weld on new hangers in the right spot for cheap. will fit as long as the vr was live axel as well
    mischa's Avatar
    mischa is offline <- 245rwkw Holden V8
    VN V6 T5 - 355 VN GRP A REP T56
    Jun 2005
    Ashbury, NSW
    Ive had a VR cat back on my VN for a while. Only difference is the final length out the back, all hangers were the same for me.
    Extractors should come out without having to move the engine, depending on brand tho.
    Quote Originally Posted by keza87 View Post
    Really who wouldn't want to give Jack a good smack in the back of the head.
    The Daily VN T5V6
    355 VN GRP A REP
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Yes, it will swap straight over. The only reason the length is different is the body, all the hangers are in the same spot.
    To remove the extractors you will need to undo the steering coupling, remove the two rack mounting bolts and push the rack over to the right as far as you can. The LHS is easy to do, the RHS is tricky. Fitting to the VN will be the same. It may also be necessary to remove the starter motor depending on the brand of extractors.
    Visit my Facebook page
Tags for this Thread
