Results 1 to 8 of 8
Thread: vn temp sensor
    ice_cold17 is offline Ice Cold
    1991 VN Executive S2
    Jun 2011
    warrawong
    Default vn temp sensor
    can anyone tell me where the temperature sensor is on a stock 91 S2 vn executive? if possible a pic of its location would be great
    pow3rslave's Avatar
    pow3rslave is offline DoNothing Member
    VP 5.0L
    Oct 2005
    eastern subs, vic
    pow3rslave's Avatar
    VP 5.0L
    Oct 2005
    eastern subs, vic
    Vn Vacationer
    Jan 2007
    Which temperature sensor are you after. The V6 has two water ones and and air temp sensor. They are all located next to each other toward the rear of the intake manifold.
    The lower one is the coolant temperature sensor, the other two are just above this with the one toward the centre of the engine being the temperature guage sender, and the outer one is the manifold air temperature sensor.
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    Quote Originally Posted by VNVacationer View Post
    Thats S1, The OP is asking about the S2 motor, which is on the front from memory..
    Power is measured in DECIBEL
    Jun 2011
    warrawong
    i need the one that sends to the guage,im disconnecting the original guage so i can put a sport one in
    FXST01's Avatar
    FXST01 is offline The Grey Man
    VP V6 Auto Sedan
    Jun 2005
    El-Arish-Shamal-Sina-Egypt
    Underneath the alternator, which you'll have to remove the fanbelt and rotate the alternator out of the way. As you look at the sensors from the front of the engine, the left one is the temp guage sender (has a spade connection) and the right one which is the coolant temp sensor (has a clip on connector, like an injector or the back of the alternator)
    Illegitimi Non Carborundum
    Jun 2011
    warrawong
    ahhh ok,well then what would ur opinions be on disconnecting it,should i just remove that guage from the instrument panel or clip the wires at the sender? coz the new guage will sit in a pod and im bolting it to the roof of the cluster where the old guage is now,but the new guage has a piece that u put in the middle of a coolant hose and then attach the guage wire to that for the temperature if that makes sense?
  1. air temp sensor behind the MAF
    By dcw group in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-07-2011, 06:11 AM
  2. Where is the water temp sensor located on 98 vt ???? (not coolant temp sensor)
    By 13thomo13 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-05-2011, 10:19 AM
  3. Q's regarding Coolant Temp & Intake air temp sensor
    By Steven M in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-02-2009, 05:08 PM
  4. Temp sensor on 5L where is it?
    By HÝPÕ-5L in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-03-2007, 03:34 PM
  5. What is this?? looking for temp sensor
    By Snotty in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-02-2006, 03:29 PM
