hi
new here, I'm trying to find some info on the T5 commodore box vn-vs models.
this is for a conversion to another car (Volvo turbo red block).
So the details so far. Correct me if I'm wrong.
T5 V6 commodore is a world class gear set with the shifter from face 22 1/2"
Input shaft 10 spline 240mm length.
The shifter position looks the best for what I need. To use US available adaptor plate I need to change the input shaft. Similar to the V6-V8 commodore swap.
What is the tooth count and bearing style on the input shaft?
I will need to swap for a US mustang T5 ( a couple of different ones available) as it is the right length for the adaptor plate and the Volvo bell housing. So i need to know which one mesh on the lay-gear.
Thanks Nick
