Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By Hangman
Thread: radiator leaking - cheapest solution?
    vn berlina s1 5.0L
    Jan 2005
    Default radiator leaking - cheapest solution?
    radiator seems to be leaking along a seam - i just top it up on a regular basis, but it's getting to the point i need to do something about it...
    what do people suggest? grab one from the wreckers? buy a reco? get a repair done?
    VP SS, Cammed VN V6 daily
    Jan 2010
    Hangman's Avatar
    Hangman is offline Torana Addict
    2 commys, 3 Toranas and a WB Panel Van
    Jan 2010
    Newcastle, home of Toranafest
    ^ you forgot pepper
    Quote Originally Posted by hakhawk View Post
    there are more pressing issues on the site, like choosing between vl's and potatos.
    VP Exec
    Jun 2005
    As it's a 5.0l and therefore a brass radiator, you might like to try cleaning the area around the leak point, roughing it up with emery paper and sealing it with an epoxy material.
    Epoxy adhesive alone works, mixing it with talcum powder makes a stronger composite material and using Devcon, JB Weld or similar is stronger again. If you spray the repair with gloss black paint it can be indistinguishable from solder.
    Allow the material to set before running the engine and pressurising the system.
    24 hr set time adhesive is stronger than the 5 min. stuff and is easier to get to flow into the split but either works.
    Cleanliness is vital for the adhesive to stick - clean with thinners as well as removing loose material, including paint, from the area with a wire brush. You might consider draining and refilling the radiator to help ensure that the area is dry.
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    got mine reconditioned a couple of weeks back was around $180 from memory (the mechanic did all the legwork while he did my intake manifold), it came back shiny black and shiny brass inside. it was full of oil sludge and blocked up lol.
    VY SS
    May 2011
    Auckland
    Could you use stopleak pallets? If you then get it reconned they won't be thankful though
    jayperformance is offline light it up
    vn Calais 5l
    Jul 2011
    griffith
    best advice is go get some quotes from the workshop's/ auto shops near you
    Vp S IRS 6 Banger
    Jul 2009
    80 bucks off ebay!
  1. VS Radiator leaking around cap
    By Kingo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-04-2010, 06:13 PM
  2. temp solution to stop radiator leaking?
    By pillzor in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-04-2010, 05:22 PM
  3. Cheapest way to replace radiator
    By LMac in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-10-2009, 03:36 PM
  4. Leaking Radiator
    By Toms 50th Ani in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-05-2008, 10:22 PM
  5. Radiator Leaking
    By jippa3000 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-05-2006, 02:37 PM
