Results 1 to 15 of 15
Like Tree1Likes
  • 1 Post By ducker85
Thread: Offsets and VP - VT Brakes??
    VP commodore
    Jul 2011
    South Australia
    Default Offsets and VP - VT Brakes??
    Is there an offset difference between commy's up to VY? It was my understanding that all rims were universal up to VZ, reason im asking is because i have a VP V6 and want to Charge it, but no good power is worth it unless you are able to stop! So i wanna do the brake upgrade, ive done searches but there is so much about commy models i dont no, can any one clear it up
    Thanks in advance and sorry if its a repeated question.
    mischa's Avatar
    mischa is offline <- 245rwkw Holden V8
    VN V6 T5 - 355 VN GRP A REP T56
    Jun 2005
    Ashbury, NSW
    Im confused, you want to know the offset of the wheels so you can upgrade the brakes? If so its got nothing to do with the brakes.
    If your after a VT brake conversion there is heaps of threads on them, do a search. If not somone should post in here soon that knows more about them.
    Also if your interested look into getting a VE brake upgrade kit.
    Quote Originally Posted by keza87 View Post
    Really who wouldn't want to give Jack a good smack in the back of the head.
    The Daily VN T5V6
    355 VN GRP A REP
    VP commodore
    Jul 2011
    South Australia
    Thats why i asked, when i did a search some guy said the offset will change due to the hub! i was confused, i use to deal with fords and the Falcon AU brake upgrade changed the offset from Eseries to Aseries i though the same principle applyed with VP-VT because of how he said it, if so how then does a VT rim fit a VP commodore?? the guy was either WRONG and trying to sound smart or there is more to it?
    Either way i just wanna no what do i need to do it (all components) and do is there a diff in rim?
    I no repeat questions S**T people off, sorry there is just so much info to sift through and most is opinionated
    de_overfiend's Avatar
    de_overfiend is offline Beef is Good
    VS Calias
    Aug 2008
    Tweed Heads
    when you install the front rotors from a vt onto a vn you will need adaptor shims. this is because the rotors will not fit well on the vn hubs. You will also need the vt brake booster and lines. Commodore rims are universal as long as they are big enough to clear the calipers when you install the rims. Any wheel offset produced by the rims can be rectified by a good wheel alignment.
    I have been looking at doing this to my vn, but i just wrecked a vt and have the whole front end setup from a vt to play with, and so i will be swapping the vn hubs with vt hubs as well to eliminate the problem.
    mischa's Avatar
    Jun 2005
    Ashbury, NSW
    Umm, Vn's dont have hubs as such. Its all one unit, disc and bearings.
    Not all commodore rims are universal, VC-VZ is but VE wheels need machining to make them fit older modles.
    The Daily VN T5V6
    355 VN GRP A REP
    VS Calias
    Aug 2008
    Tweed Heads
    VP commodore
    Jul 2011
    South Australia
    Question
    I have seen kits that say they do NOT require a VT booster and that a VT booster is not as easy as plug and play, it requires some stuffen around? By shimes do you mean the conversion hub? It was my understanding all you need is, VT brake calipers, VT brake pads, VT brake rotors, those conversion hubs( i dont no what they are, or if they can be canibilised off the VT or another car) and brake lines (again dunno if they have to be made or u can get from another vehical) That was all, possibly new VP wheel bearings if the others are no good? Is this correct?
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    You buy the VT calipers, discs, conversion hubs off ebay or hoppers stoppers which use the same bearings as original, VT master cyl, VS booster, flare adapters, custom brake lines and your set.
    VP commodore
    Jul 2011
    South Australia
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    VP commodore
    Jul 2011
    South Australia
    ducker85's Avatar
    ducker85 is offline Calais man
    09 VE clubbie R8
    Oct 2008
    Adelaide SA
    VP IRS offset is 28P (calais wheels) or 35P (HSV wheels) because the VT wheels 48P rub on the body.
    This make no difference up front, I ran everything on my VP's VY 19's 48P offset to the HSV VP wheels 35P and the stock Calais wheels 28P. They all bolt up fine on the front
    VP commodore
    Jul 2011
    South Australia
    ducker85's Avatar
    09 VE clubbie R8
    Oct 2008
    Adelaide SA
    Quote Originally Posted by psychotic46 View Post
    Did you ever do the brake upgrade?
    No but if its only Twin pot VT brakes it wont matter all those wheels cleared the HSV twin pots on Dads Senator
    and VT's come on 15s stock with twin pots. I just noticed not one person told you any offsets so there the 3 main 1's I know about
  15. #15
    VP commodore
    Jul 2011
    South Australia
    ok so my stock 15" will do the job! Cool
  1. Aggressive Offsets on VU SS
    By MR 1JZ in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-05-2011, 10:34 AM
  2. VP WHEEL OFFSETS(inc IRS!)
    By NOGEN 3 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-08-2008, 06:00 PM
  3. Stud Patterns and Offsets??
    By EvoVIIIJDM in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 25-02-2007, 05:33 PM
  4. Vp Calais rims and offsets
    By G4orce in forum General
    Last Post: 04-08-2005, 04:48 PM
  5. Tyre Offsets
    By Calculus in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-11-2003, 07:49 PM
