Results 1 to 7 of 7
Thread: Replacing my VP auto trans. How to?
    VP Calais 3.8L
    Jan 2006
    Ringwood, Vic
    Default Replacing my VP auto trans. How to?
    Hey guys.
    In the next couple of weeks I'm looking to replace my slipping auto trans.
    Just wondering if anyone can give me some info on steps and best ways to do this or post links to any relevant info.
    I'll be doing it at home and haven't really looked much into how I go about doing it.
    I'd rather not take it to a workshop as It's not worth the cost and I'd rather learn myself.
    Thanks, Ryan.
    SGM304
    Jul 2010
    Kadina
    personally i wouldnt even try and do it without a hoist, to hard, take about 4 hours if you havent done one, there pretty easy, take off tail shaft, exhaust, undo cooler lines, take out bell housing bolts take it out. be pretty hard to try and line it up and get it back in on the ground.
    vs commodore
    Oct 2009
    Tamworth NSW
    Find a decent set of car ramps so the car is up high enough to work under easily.Also you will need a mate or two to help lift the trans out/in.Autos arent that hard to line up when reinstalling the trans,just make sure that the torque converter is clicked back in the trans properly,it will click back about 2 or 3 times before its fully seated in the trans..Id also suggest you get a workshop manual and follow its steps to remove/reinstall the trans,it makes it a lot easier that way.
    304runner's Avatar
    304runner is offline ( .Y. )
    VR 5.0 Ute & a 4runner with a VS SS trasplant
    Mar 2011
    Central Coast NSW
    Yeah I have done one in a drive way before. Plenty of swearing. A trolly jack is a must at the very lest, you need something to support the box and have it slide back at the same time.
    VP Exec
    Jun 2005
    Yeah, it's an unpleasant job to do on the ground.
    The auto cooler lines can be tricky. I would not attempt them without a pipe spanner - 1/2" or 5/8"? can't recall which.
    You need to undo the three bolts between the torque converter and flex plate before removing the trans.. The torque converter will stay with the trans.. Apply Loctite or similar when reinstalling them.
    A plug for the extension housing - the front yoke from an old tailshaft is ideal - will avoid a mess when manouevring the trans out.
    Washing/degreasing under the car first - a day or two before, so it's dry - will make it more pleasant to work on.
    The trans. dipstick tube will have to be removed to get the trans. out from under the car.
    I would use 4 stands rather than ramps as it's easier to work on everything with the car level.
    A trolley jack - a real one not a cheap toy - and a block of wood to spread the load across the pan will help a lot in getting the trans. in and out unless you (and your mate?) are built like Mr Universe.
    Flush the auto. cooler and lines through to avoid contamination killing the replacement trans.
    Adjust the kickdown cable when it's all back in: push the locking tab in to release the cable then fully open the throttle by hand to the stop to drag the cable back to it's adjusted position. Be carefull when removing that cable from the throttle body too; it's easy to break the connector.
    Use a screwdriver wedged between the rear tailshaft uni. joints and the floor to stop the tailshaft rotating when undoing the tailshaft bolts but be careful of the dust boots on the uni. joints when doing so.
    VP Calais 3.8L
    Jan 2006
    Ringwood, Vic
    Yea I have two small trolley jacks and a large low pro trolley jack and stands.
    Hopefully it goes in alright, wish me luck and thanks guys.
    vn calais 5.0
    Jun 2011
    victoria
    Have you had it serviced to fix the slipping prob?
  1. Replacing 4-spd trans with 5-spd
    By cavz in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 11-05-2010, 08:54 PM
  2. Changing a Vr auto trans to a vn auto trans
    By phildo_mmmk in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-01-2010, 11:35 AM
  3. Replacing Shift Solenoids in VS auto trans.
    By Portunio in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-09-2009, 07:12 PM
  4. Automatic Trans needs replacing
    By AlpineRaven in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-02-2008, 04:46 PM
  5. Auto Trans problem when hot - need a trans cooler ??
    By woteva in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-12-2007, 11:41 PM
