Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By calais_cruzin
Thread: Weird noise under passenger footwell when braking??
    VN Exectutive 1990 3.8
    Mar 2010
    Default Weird noise under passenger footwell when braking??
    Hey I'm getting a weird noise down in the passenger foot well when braking and taking off again. The sound is like a leaf fluttering in a fan, but why only when I brake, are the brake vaccums the same as the fan. First I thought it was the computer making a noise, what could it be? has anyone else had that, I only noticed cause i turned my stereo off.
    calais_cruzin's Avatar
    calais_cruzin is offline Calais_Rattling....
    92 VP Calais 3.8
    May 2006
    Gold Coast
    Not something caught in the blower fan for interior?
    Id check behind ur glovebox, probly lost a bit of paper outta the glovey and has gone into the blower fan
    Or its it lower, sounds like its out of the car?
    ________________________________________
    '88 VN Sedan
    Jun 2011
    If it's only when your braking then I'd be inclined to think it's something to do with the brakes themselves or something that comes under load when braking, like castor bars. Pull the left front wheel off & check that everything appears to be in order to start with. Pay attention to the wheel itself & make sure that there isn't anything stuck on the inside of it or into the tyre. Make sure the two caliper bolts are tight & that the caliper isn't moving around. If all looks well then I'd probably remove the caliper & check if there is a small stone or anything like that jammed between the pads & the disc. If not then I would move onto the suspension components checking that all the bushes & ball joints are in good order.
    '88 VN Sedan, stock V6.
    vp calais, vn calais, vp berlina all 3.8 litre
    Aug 2008
    Pascoe Vale South, MEL
    mine sometimes makes a squeaking noise on the driverside when breaking. almost like a binding door hinge. i went under and noticed one of those shims that holds the break line to the shock unit is missing and the line is just floating around. think thats what my noise is. gotta get over the wreckers and grab one....
    dont sweat the petty... pet the sweaty...
    Mar 2010
    hey guys, had alook at the front wheels and calipers and everything seems fine, is there an easy way to get to the fan under the dash like to get the vaccum hose in there, I think there are leaves in there
  1. Braking noise
    By hN! in forum VY Holden Commodore (2002 - 2004)
    Last Post: 25-05-2011, 11:42 PM
  2. Grinding noise upon braking
    By vn2nv in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-01-2011, 03:03 PM
  3. Water getting into rear passenger LHS footwell
    By michaelw in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-01-2010, 10:33 PM
  4. Where is the footwell light on the Passenger side of a VR Calais
    By VRCalaisVR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-09-2009, 12:03 PM
  5. Weird noise when braking
    By QWK-11E in forum V8 Development and Modification
    Last Post: 20-10-2006, 01:34 AM
