hello fine owners of holdens
when i go driving my cluster makes beeping noise randomly all the time didnt care for it at first tried to live wif it but its gettin on my last nerve.
i have pulled the handbrake slightly up and dowm a few times just enough to see the light comes on and off but still beeping continues.
can someone please help me
ideas advice would be greatly much appreciated
cheeeeeeeeeers!!!
check to see if your charging system is producing 13.5volts or greater. that's all the advise i can give you without looking at the vehicle.
was has charging system got to do wif it??![]()
its just a warning to alert you sumthing is not up, have you fondled with the trip comp settings lately? you might have set the speed limit warning down too low
or just remove the chime
can i reset the ecu or sumthing
could it be a service the car warning cause the heard that when mechanics service cars they reset the ecu to stop warning or sumthing
Home FAQ/Beeps.
Beeping Codes from Level 3 Clusters
Overspeed A = T4 pause (1) T3
Low fuel B = T2 pause (1) T3 pause (4) repeated 5 times
Hot engine C = T1 pause (1) T2 pause (1) T3 pause (1) T3 pause (1) T3 pause (1) T3 pause (1)
Park brake C = T1 pause (1) T2 pause (1) T3 no pause T3 pause (1) T3 pause (1) T3 pause (1)
Press remote B = T2 pause (1) T3 pause (4) repeated 5 times
T1 = 2560 Hz 1/8 sec
T2 = 3200 Hz 1/8 sec
T3 = 4266 Hz 1/8 sec
T4 = 6400 Hz 1/8 sec
Pause = 1/8 sec
Beeps from the cluster ^^.
Most probably temp gauge warning or hand brake switch not working.
and 3 Dangerous non ABS VN's
is the handbrake switch under the centre console somewhere???
how do i fiddle with the hand brake to stop the beeping
is it shorting somewhere has anyone else had this problem
ani suggestions
will be much appreciated![]()
i have fiddeld with the handbrake wire i have cutt it then drove the car but the beeping continues so i connected back up and beeping still continued
now i am wondering if it is the temp sender wire if so how will i go about dealing with it
ani help would be wonderful thank you
cheers![]()
Think 88greenvn posted above what the beeping from the cluster could indicate. Is there different changes in pitch(sound) from the chime or is it just the same constant sound.
I am sure the answer is a few posts above
